Boundary Layer Thickness Variation
Old   July 23, 2020, 08:21
Default Boundary Layer Thickness Variation
MA
mazhar16823 is on a distinguished road
Hi Everyone,
I have noticed that the BL Thickness (boundary layer edge) post-simulation is less than what I provided to the prism layer mesher. In this case, do I need to reduce the number of prism layers and increase the growth rate? or I have to keep the same number of prism layers and reduce the growth rate to encapsulate the whole boundary layer?
Thanks for your time.
Best regards,
mazhar16823 is offline   Reply With Quote
Old   December 1, 2020, 18:47
Kira
aero_head is on a distinguished road
Hello Mazhar,
If you are using ICEM CFD, it is better to generate one prism layer of the total thickness of the boundary layer. So I would choose the section option.
You can then use Edit Mesh > Split Mesh >Split Prisms to divide this layer into the required number of layers. To ensure the first layer is equal to the thickness that gives you y+ = 1, you can use Fixed initial height option.
I noticed this is from awhile back, what did you do in the end?
aero_head is offline   Reply With Quote
Out File does not show Imbalance in % Mmaragann CFX 5 January 20, 2017 11:20
Error - Solar absorber - Solar Thermal Radiation MichaelK CFX 12 September 1, 2016 06:15
Wrong flow in ratating domain problem Sanyo CFX 17 August 15, 2015 07:20
Questions about Boundary Layer Thickness and Turbulence Models famerfamer STAR-CCM+ 3 July 12, 2012 10:47
boundary layer thickness 98.4F Main CFD Forum 1 December 29, 2000 08:23
