July 9, 2020, 21:47 |
Turbulent Velocity Scale
Blegh
Rep Power: 6 |
Hi, for my initial conditions I need to define the turbulent velocity scale (k-Omega model). But what exactly is the turbulent velocity scale? Acoording to star-ccm+ it's defined as (turbulent length scale / turbulent time scale). However what is it exactly? The speed of the largest eddies? When I look up the equations for K-Omega SST I don't see this coming up. I can't find any information about it. The only thing Star-CCM+ tells me is that for pipe flows it should be the same as the inlet velocity. However when I look at an example of one of their tutorials (pipe flow) they don't put in the value of the inlet velocity but instead 10% of it. Can somebody tell me what effects this value has on my results?
Thank you very much! Last edited by The; July 9, 2020 at 21:49. Reason: spelling |
Turbulent Velocity Scale and Turbulent Viscosity Ratio | mazhar16823 | Main CFD Forum | 2 | February 4, 2023 10:21 |
Drag Force Ratio for Flat Plate | Rob Wilk | Main CFD Forum | 40 | May 10, 2020 05:47 |
Problem with divergence | TDK | FLUENT | 13 | December 14, 2018 07:00 |
Interface treatment in turbulent model and its length scale. | paka | OpenFOAM Running, Solving & CFD | 0 | February 15, 2014 03:02 |
k-epsilon: Defining turbulent intensity and length scale? | klausb | OpenFOAM | 0 | January 23, 2011 08:28 |
