July 8, 2020, 17:07 |
Simulate a coil in air (heat transfer)
Suk Tan
Rep Power: 6 |
I try to simulate heat transfer of a circular coil conducting DC current. The coil is assumed floating in static air. It is modeled as follows.
1, axisymmetry is employed. 2, no-slip BC is applied to the coil represented by a rectangle 3, heat source is applied to the "coil" rectangle 4, laminar flow, ideal gas I have the following questions: 1, Is the model okay? 2, Can it be described as "natural convection, external flow problem"? 3, What should I use for the top, bottom and right-hand (RH) side BC? I have the following combinations being considered. a, RH, top and bottom: norm velocity = 0; all temp = ambient temp b, RH: norm velocity = 0, top: outlet, bottom: zero pressure inlet; all temp = ambient temp c, RH, top and bottom: zero pressure; all temp = ambient temp Which one is correct? Or all are incorrect? I expect to see flow for hot air rising and cold air falling in the result, air circulation around the coil. Thank you. |
Setting the height of the stream in the free channel | kevinmccartin | CFX | 12 | October 13, 2022 22:43 |
problem in transient heat transfer of ground heat exchanger | teguhtf | FLUENT | 0 | April 23, 2020 06:46 |
Boundary conditions for heat transfer between a hot plate and the ambient air | buffi | OpenFOAM Pre-Processing | 2 | August 28, 2015 08:05 |
Heat Transfer Coefficient of air vs Velocity | shreesha87 | Main CFD Forum | 1 | June 10, 2014 04:08 |
Convective / Conductive Heat Transfer in Hypersonic flows | enigma | Main CFD Forum | 2 | November 1, 2009 23:53 |
