Convert msh format 2.2 to 4.1
Old   July 4, 2020, 23:33
Default Convert msh format 2.2 to 4.1
Sep
Sepehr
Sep is on a distinguished road
I am currently working with Dealii for a project. Currently, Dealii can only read .msh files of legacy 2 format (2.2). I am trying to update the source code for it to be able to read the new MSH format (4.1)
I was wondering if this has been done before?
Thank you for your time!
Sep is offline   Reply With Quote
Old   July 6, 2020, 16:44
naffrancois is on a distinguished road
Have you read gmsh documentation ? File format specification is well detailed.
https://gmsh.info/doc/texinfo/gmsh.html#File-formats
Nevertheless, you can still export your mesh files to legacy v2 format from the latest gmsh versions, is there a specific feature you need from v4 format ?
naffrancois is offline   Reply With Quote
Old   July 6, 2020, 18:51
Sep
Sepehr
Hello!
Thank you for your reply!
So I am aware that gmsh is able to generate various versions of .msh file from a .geo file.
What I am trying to do is write a code that can read a version 4.1 .msh file and extract the information needed to make a version 2.2 .msh file. I was wondering if this had been done before!
gmsh msh format converter
How to convert the CAD file to FDS format? PIN Main CFD Forum 6 November 9, 2015 02:54
[Commercial meshers] Problem with Mesh conversion Gambit msh Foam Rachid BANNARI (Bannari) OpenFOAM Meshing & Mesh Conversion 25 September 11, 2011 08:58
Convert a msh file into a ASCII file antonio ANSYS Meshing & Geometry 4 March 15, 2010 14:34
OpenFOAM native format data visualization and workflow zeliboba OpenFOAM Post-Processing 0 September 12, 2008 09:44
Convert FLUENT mesh to some other format for STAR? Jiaying Xu FLUENT 3 December 5, 2002 09:15
