Turning mas flow rate into concentration flux |
June 29, 2020, 07:57 |
Gerry Kan
Rep Power: 11 |
Howdy People:
I have a seemingly trivial issue, but I have been stuck on this literally for weeks. I hope a different pairs of eyes would give me some insight. Currently I have an inlet boundary, in which a mixture of air and a trace amount of another gas phase species enter my flow domain. From our experimental observations, I have: 1) Mass flow rate of this trace species, in kg/s 2) Ambient density of the mixture at the inlet boundary Note that I have no control over the experimental side of things so I am stuck with what I am given. However, at least for OpenFOAM, I need to turn this into some kind of concentration flux rate. For that I need to somehow obtain the mass flow rate of the mixture, which I don't have. The question is how? In the meantime I have tried the following with no avail: a) Assume mixture mass by estimating the air volume using the first layer of cells adjacent to the inlet boundary. The end calculation simply gave me the mean cell height with variations due to mixture density b) Assume unit volume and estimate the concentration flux. This led to a simple division ( y_species = m_species / rho_mixture, assuming volume of 1 cu m), attractive but dubious. c) Assume constant mass fraction and work out the mass flow rate. This seems most plausible but more of the "rule-of-thumb" rather than the "scientific" variety. d) Work out the mixture mass flow rate independently, but this requires more information than I have, and additional assumptions will risk going back to (c). Any further ideas would be greatly appreciated, Gerry. |
Run-time postprocessing - incorrect flow rate through faceZone | billie | OpenFOAM Post-Processing | 54 | December 2, 2013 06:55 |
mass flow rate... | sanjar | OpenFOAM Running, Solving & CFD | 1 | December 2, 2013 01:09 |
How to calculate phase flow rate? | sangramroy | FLUENT | 0 | January 11, 2012 14:02 |
Discrete Phase & Mass Flow Rate | MagnusZeus | FLUENT | 0 | December 2, 2011 18:57 |
How are the mass flux and mass flow rate defined? | Miles | Siemens | 2 | November 7, 2002 09:45 |
