June 23, 2020, 14:25 |
Continuity errors
Jagan Mohan
Rep Power: 6 |
Hello fiends, foamLog creates three text files for continuity equation in openFOAM.
1. What is the difference between local, global and cumulative continuity errors? How to judge convergence, (besides residuals from governing equations solved)? Thank you, Jagan Mohan |
June 24, 2020, 16:53 |
Troy Snyder
Rep Power: 19 |
For incompressible flows:
volScalarField contErr(fvc::div(phi)); scalar sumLocalContErr = runTime.deltaTValue()* mag(contErr)().weightedAverage(mesh.V()).value(); scalar globalContErr = runTime.deltaTValue()* contErr.weightedAverage(mesh.V()).value(); cumulativeContErr += globalContErr; Info<< "time step continuity errors : sum local = " << sumLocalContErr << ", global = " << globalContErr << ", cumulative = " << cumulativeContErr << endl; Global: and cumulative is the sum of the global continuity error over the total number of time steps. |
October 16, 2020, 17:10 |
time step continuity errors for "sum local" and "global"
Mahdi
Rep Power: 6 |
Hi everyone,
Lately I have been working on an algorithm for a two-phase solver to couple the pressure and velocity fields. The method is Similar to PC_SIMPLE algorithm if you have heard about it (something like a phase coupled SIMPLE algorithm) …. I believe that I have modified the pEqn.H file correctly, but I feel I am missing something obvious somewhere, as once I look at the time step continuity errors, my local error is always much larger than the global error: " time step continuity errors for sum local = 1.74033576902e-07, global = -9.93993329672e-21, cumulative = -8.2037380338e-16 " Interestingly, the simulation doesn't diverge but my local error never gets smaller than 1e-7 which is a bit odd for me. Does anyone have any idea why this might be happening? I have a feeling that it should be something small and obvious that I am missing here …. Cheers, Mahdi |
continuity convergence |
Building OpenFOAM1.7.0 from source | ata | OpenFOAM Installation | 46 | March 6, 2022 14:21 |
LES, Courant Number, Crash, Sudden | Alhasan | OpenFOAM Running, Solving & CFD | 5 | November 22, 2019 03:05 |
decompose dependent solution | arionfard | OpenFOAM | 3 | December 10, 2018 10:36 |
InterFoam negative alpha | karasa03 | OpenFOAM | 7 | December 12, 2013 04:41 |
AMI interDyMFoam for mixer nu problem | danny123 | OpenFOAM Programming & Development | 8 | September 6, 2013 03:34 |
