June 20, 2020, 16:58 |
Meshing Stops after reducing the cell size
MA
Rep Power: 6 |
Hi everyone,
I am using the SST Transition Model in Starccm+. It is recommended to have mesh on the turbine blade 0.5% of the lowest chord which in my case should be 0.00035 m. For now I am using the custom control for the blade and the cell size is 0.03 m and already 11 M cells, if I further reduce it, it gives a red warning and meshing stops. I am using the PC with two cores and 15 GB RAM. Any idea? Thanks for your time. |
June 20, 2020, 17:19 |
Alex
Rep Power: 49 |
My first guess would be that your PC is running out of memory with this many cells. 15GB is not a whole lot for more than 11 million cells.
No idea what a "red warning" might be. Maybe check top or taskmanager to see what is going on with memory consumption when the error occurs. |
June 20, 2020, 17:49 |
#3 | |
MA
Rep Power: 6 |
Sorry the RAM is 15.9 GB however I noticed that it is fully utililizing the RAM around 15.3/15.9 GB. |
June 20, 2020, 18:49 |
Alex
Rep Power: 49 |
Then that's probably your problem. You would need more RAM. And solving such a large mesh on a dual-core CPU is going to take a while.
June 20, 2020, 18:53 |
MA
Rep Power: 6 |
[blockMesh] edges not aligned with or perpendicular to non-empty directions | ynos | OpenFOAM Meshing & Mesh Conversion | 6 | March 26, 2020 16:02 |
[ANSYS Meshing] Is it possible to generate mesh in different cell zones in Ansys meshing? | aja1345 | ANSYS Meshing & Geometry | 0 | October 3, 2018 15:22 |
DPM droplets size limitations for a given cell size (or vice versa) | ItayM | FLUENT | 0 | September 28, 2015 10:15 |
Journal file error | magicalmarshmallow | FLUENT | 3 | April 4, 2014 13:25 |
Problems in compiling paraview in Suse 10.3 platform | chiven | OpenFOAM Installation | 3 | December 1, 2009 08:21 |
