June 20, 2020, 04:20 |
Modelling a piston by inlet
Suk Tan
Rep Power: 6 |
Can I simply use an inlet to model the flow generated by a piston? A circular piston is located somewhere on a face of a rectangular box. It vibrates back and forth in sinusoidal manner. I want to simulate the flow in the box.
Thanks. |
June 20, 2020, 04:31 |
#2 | |
Filippo Maria Denaro
Rep Power: 73 |
If the movement of the piston in the is small, you could use a sinusoidal normal velocity compontent on the boundary. This is like a synthetic jet condition see https://en.wikipedia.org/wiki/Synthetic_jet But if the movement is large that can be quite approximate |
June 20, 2020, 21:01 |
Suk Tan
Rep Power: 6 |
June 21, 2020, 03:02 |
Rep Power: 73 |
June 21, 2020, 21:19 |
Suk Tan
Rep Power: 6 |
Thanks again Filippo. Is selection of BC type: velocity, pressure and mass flow matter? Which can do a better job to simulate the flow generated by the piston?
June 22, 2020, 04:09 |
#6 | |
Rep Power: 73 |
I suppose that the piston does not allow a net mass to enter, you could prescribe e normal velocity on the boundary, a the whole period it is inflow and outflow so that the total mass vanishes. |
June 22, 2020, 04:35 |
Suk Tan
Rep Power: 6 |
From the text book, an outlet is necessary for any case with an inlet (potential mass source). If the rectangular box is essentially sealed and there is only an inlet, will I encounter numerical problem? It is said the mass is not conserved.
At the moment, air (fluid) within the box is incompressible. |
June 22, 2020, 04:45 |
#8 | |
Rep Power: 73 |
I was thinking your problem was modelled by a compressible flow. |
June 22, 2020, 04:56 |
#9 |
Suk Tan
Rep Power: 6 |
[IHFOAM] The IHFOAM Thread | Phicau | OpenFOAM Community Contributions | 392 | September 8, 2023 18:10 |
interFoam wave propagation and explosion of Courant number and residuals | ChiaraViola | OpenFOAM Running, Solving & CFD | 1 | June 26, 2019 05:36 |
Reversed flow using pressure inlet and outlet? | here_for_help | FLUENT | 0 | September 28, 2018 15:20 |
Domain Reference Pressure and mass flow inlet boundary | AdidaKK | CFX | 75 | August 20, 2018 05:37 |
Simple piston modelling with dynamic mesh | soliddesign | FLUENT | 1 | March 7, 2014 12:04 |
