air bubble DPM
Old   June 18, 2020, 11:22
Default air bubble DPM
Giuseppe
pezarello86 is on a distinguished road
hello,
i want to simulate the air bubble flow from the bottom of my domain (it is a 3D rectangular domain) in a two-coupling to see the effect of bubble curtain on the fluid dynamic. At the inlet i have a velocity inlet and a scalar which has the role to simulate a sediment. the simluations aims at to represent the barrier effect of air bubble on the sediment. Tt seems that the DPM does not influence the fluid dynamics of the sediment (the transported scalar). If a run the same simulations without scalar the DPM sounds good.
thanks in advance
pezarello86 is offline   Reply With Quote
Old   June 18, 2020, 14:03
Default Dpm
vinerm's Avatar
Vinerm
vinerm will become famous soon enough
Discrete Particles do not affect UDS. They only affect the flow-field (or other fields, such as, thermal and species, depending upon the model). UDS is affected only by the flow-field, until and unless user uses some UDF or other approach to include some effects of Lagrangian Particles. So, if you run UDS along with flow and DPM, you should see the effects, provided Interaction with Continuous Phase is enabled in DPM.
Regards,
Vinerm
PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority.
vinerm is offline   Reply With Quote
Old   June 18, 2020, 14:41
Giuseppe
Hi Vinerm, thank you so much.
I made a simulation in this way but i did not see any variations about the scalar: in theory, and as you wrote, i should see the streamline of the flow field turn around the DPM (for sure in two way coupling, i.e. Interaction with Continuous Phase) but i do not see variations of scalar. Can i send you my model?
Old   June 19, 2020, 08:47
Default Diffusivity of Scalar
vinerm's Avatar
Vinerm
How are you implementing the diffusivity for the scalar? By default, Fluent does not take turbulence into account. User needs to implement that via UDF. And that will make a lot of difference.
Regards,
Vinerm
air bubble, dpm, scalar, two-way coupling
mass diffusion between air bubble and water AKHIL123 Main CFD Forum 0 May 9, 2019 06:42
Air entrainment model setup for spillway oajor FLOW-3D 4 November 17, 2016 13:02
air bubble in a tank harshrox3 FLUENT 0 November 10, 2015 10:37
DPM - UDF for fluctuating bubble size Jaroslav Kotara FLUENT 1 April 19, 2006 10:02
Query on VOF for Bubble rise Vamsi Main CFD Forum 0 December 22, 2005 01:02
