Aerodynamics: Power Coefficient for HAWT
Old   June 16, 2020, 14:12
Default Aerodynamics: Power Coefficient for HAWT
MA
mazhar16823 is on a distinguished road
Hi Everyone,
I am in a little confusion. I saw some of the CFD users have evaluated the power coefficient for their VAWT/HAWT using the formula Cp = Cm*TSR. I couldn't find the reference for this in literature. Is it recommended to use this for HAWT?
Actually, I am simulating the flow around a horizontal axis wind turbine blade, where to calculate the Cm I created a Report in STARCCM+ and defined the reference area as 1/3 of swept area (as I have one blade). So after computing average Cm do I need to use Cp = TSR*Cm or Cm*TSR*3??
Or if there is another approach to be used?
Thanks for your time.
mazhar16823 is offline   Reply With Quote
Power coefficient from Moment Coefficient mazhar16823 Main CFD Forum 0 May 20, 2020 14:02
Calculating the Cp (Power Coefficient ) for a cross flow vertical wind turbine AS_Aero CFX 13 February 14, 2018 17:57
Ansys CFX problem: unexpected very high temperatures in premix laminar combustion faizan_habib7 CFX 4 February 1, 2016 18:00
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 07:28
Automotive test case vinz OpenFOAM Running, Solving & CFD 98 October 27, 2008 09:43
