Air circulation in room, mass flow problem!!
Old   June 16, 2020, 03:55
Default Air circulation in room, mass flow problem!!
ali
sorkhani is on a distinguished road
Hi guys,
My case is a room with inlet face and same face in another wall as outlet.
B.C in inlet is mass flow inlet
B.C in outlet is pressure outlet(0 pa)
After fluent solution converge, balance of mass in inlet and outlet is good.
Problem:
Why Velocity Magnitude is different for inlet and outlet boundries!!!!!?
Area is equal , density is constant.
sorkhani is offline   Reply With Quote
Old   June 16, 2020, 04:25
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
Originally Posted by sorkhani View Post
Hi guys,
Problem:
Could you superimpose the inlet and outlet velocity profiles on a single plot? I want to check the area of the curves.
FMDenaro is offline   Reply With Quote
Old   June 23, 2020, 03:00
ali
http://s12.picofile.com/file/8400849...623_102542.jpg
This is superimpose of velocity magnitude at diameter line of inlet and outlet (my case is 3D)
Old   June 23, 2020, 04:20
If the flow rate is the same in inlet and outlet that does not imply you must have the same velocity profiles.
However the outlet profile seems quite strange.
Old   June 27, 2020, 06:23
ali
this is my problem !!!
every convergence parameter is good, but the velocity is so wrong!!
when the outlet around area mesh is Hex, outlet velocity is equal to inlet vel.
fluent, mass flow inlet, velocity magnitude
Mass imbalance problem in multiphase water and steam CFX case Antech CFX 1 October 26, 2020 05:03
Problem with an old Simulation FrankW CFX 3 February 8, 2016 05:28
Two Mass flow inlet bc convergence problem nabidinhomessi Main CFD Forum 5 December 14, 2015 08:11
Wrong flow in ratating domain problem Sanyo CFX 17 August 15, 2015 07:20
Radiation interface hinca CFX 15 January 26, 2014 18:11
