Changing parameter value using UDF
Old   June 11, 2020, 11:38
Default Changing parameter value using UDF
Manish Vankudre
manish1308 is on a distinguished road
Hello everyone,
I have created a parameter named "parameter-1" using the input-parameter TUI command. I have created the parameter to be used in udf-side and it says the (id to be used in udf is- "real-1").I am able to access the parameter in the UDF by using the command RP_Get_Input_Parameter("real-1").
Now I want to change the value of this variables using the UDF . Is it possible to do so?
Any help is appreciated.
Thank you
manish1308 is offline   Reply With Quote
fluent - udf
Monitoring/writing a single parameter from UDF. nvarma FLUENT 5 September 2, 2018 22:52
Scheme (or UDF) load Parameter value HHOS FLUENT 0 September 4, 2017 05:25
Using UDF to define parameter Oleg V. Fluent UDF and Scheme Programming 2 January 24, 2017 03:55
udf for changing outlet BC of nozzle amirho Fluent UDF and Scheme Programming 0 January 26, 2016 10:38
udf for changing rotational velocity peterchen Fluent UDF and Scheme Programming 4 October 19, 2010 07:43
