Open source code for multi-phase pipeline simulation |
Ruslan
Rep Power: 9 ![]() |
Dear all,
I will be very glad if anyone can suggest/recommend some open source code or libraries which can deal with multiphase pipe flows. Python-based libraries would be perfect. Basically, I want to do a simple pipe flow analysis. I have point A ( where temperature, velocity, liquid, and gas concentration is specified) and I need to know the information in point B ( pressure drop, temperature, liquid and gas concentration, etc) by taking into accoi=unt pipe geometry ( bending, roughness, diameter). Basically this is a kind of simple problem of fluid mechanics. many thanks and best wishes |
multiphase, open source code, pipelines |
[swak4Foam] swak4foam for OpenFOAM 4.0 | mnikku | OpenFOAM Community Contributions | 80 | May 17, 2022 08:06 |
[foam-extend.org] Problems installing foam-extend-4.0 on openSUSE 42.2 and Ubuntu 16.04 | ordinary | OpenFOAM Installation | 19 | September 3, 2019 18:13 |
polynomial BC | srv537 | OpenFOAM Pre-Processing | 4 | December 3, 2016 09:07 |
OpenFOAM without MPI | kokizzu | OpenFOAM Installation | 4 | May 26, 2014 09:17 |
[swak4Foam] swak4Foam-groovyBC build problem | zxj160 | OpenFOAM Community Contributions | 18 | July 30, 2013 13:14 |
