Boundary condition to the edge that is open to atmosphere
Old   June 7, 2020, 12:24
Default Boundary condition to the edge that is open to atmosphere
ARAVIND SRIDHARA
aravind vashista is on a distinguished road
Hii all
I am simulating a simple 2D diffusion flame that is open to the atmosphere. The Computational domain is as shown. It is having following inlet conditions
Air= mass flow inlet
Fuel=mass flow inlet
Burner wall= Wall
Outlet= Pressure outlet
Axis=Axis
and another edge that is open to the atmosphere. What boundary condition should I specify for this edge? Can I specify a pressure outlet or interior, or pressure far field?
I appreciate your valuable time for reading this post and I am hoping to get valuable suggestions
Thank you
aravind vashista is offline   Reply With Quote
Old   June 7, 2020, 13:57
duri
duri is on a distinguished road
It is better to reconsider the domain size for better accuracy.
For the given domain, mixing and shear layer would penetrate the boundaries hence outflow has to be a non reflecting boundary condition.
The open to atmosphere can be pressure far field, because pressure outlet would approximate reverse flow in the re-circulation zone near wall. Pressure far field try to force static pressure at boundary which is also not accurate but I think it is better than outlet. Interior won't work at boundary it should be either periodic or symmetry.
duri is offline   Reply With Quote
Old   June 8, 2020, 02:26
ARAVIND SRIDHARA
Thank you for your response, I will increase my domain size and implement the far-field condition. However, should I give some flow in the axial direction (very low Mach number of the order e-2) or make it zero?
boundary condition, pressure far field, pressure outlet
[OpenFOAM.com] swak4foam compiling issues on a cluster saj216 OpenFOAM Installation 5 January 17, 2023 17:05
[foam-extend.org] Problems installing foam-extend-4.0 on openSUSE 42.2 and Ubuntu 16.04 ordinary OpenFOAM Installation 19 September 3, 2019 19:13
what is swap4foam ?? AB08 OpenFOAM 28 February 2, 2016 02:22
Wrong flow in ratating domain problem Sanyo CFX 17 August 15, 2015 07:20
centOS 5.6 : paraFoam not working yossi OpenFOAM Installation 2 October 9, 2013 02:41
