Critical DiffiusionNumber / Peclet-Number
Old   June 4, 2020, 09:45
Default ---------
Lennard Porter
lolo97 is on a distinguished road
Hi everybody,
I´m new to thermal transient simulations, and have come across a problem.
I searched for anwers, and have found a lot, but nothing really answering my questions.
I have a transient thermal simulation, with a stationary flowfield (only solving energy-equation, so no need to look after Courant-Number).
The flowtemperature changes in time, transfering the heat into a glass-shield. So i have heatconduction within the glass.
Is there a general (theoretical) critical number for the Diffusion-Number (in OpenFOAM)?
For as far as i know, the Courant-Number is defined as CFL=\frac{w \cdot \Delta t}{\Delta x}, and usually has to be smaller than 1, for stability/precision reasons due to loss of information being "passed through" a cell within a single timestep.
The Diffusion-Number is defined as DN=\frac{a \cdot \Delta t}{(\Delta x)^2}, with a being a material specific constant a=\frac{\lambda }{\rho \cdot c_p}.
How do I calculate a critical timestep for heattransfer (conduction) issues? Is there a critical Diffusion-Number , like there is for Peclet<2?
Thanks in advance for your help!
Best regards
Lolo
lolo97 is offline   Reply With Quote
Old   June 5, 2020, 01:17
Lucky
The diffusion-number for heat conduction is called Fourier number. There also is a stability criterion which ends up being around 1.
But just like the CFL criterion for Courant number, it highly depends on the problem. If you really want to know what that exact number is, you need to do the stability analysis in depth (or at least state all your numerics/discretization/etc.)
And although you have a stationary velocity field, you still have an advection term, which means a similar Courant number constraint still applies.
Old   June 5, 2020, 04:40
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
Originally Posted by lolo97 View Post
Hi everybody,
If I apply the same rules as for the CFL-Number (DN<=1, and x = cell-length (0,5mm)), my critical timestep is t_{critical}=\frac{(\Delta x)^2 \cdot 1}{a}=\frac{0,5 \cdot 10^{-3} m^2 \cdot 1}{4\cdot 10^{-7} \frac{m^2}{s}}=0,625s.
Is that somewhat realistic? (For heatconduction in glass)
If not so, what do I have to look out for? How do I calculate a critical timestep for heattransfer (conduction) issues? Is there a critical Diffusion-Number , like there is for Peclet<2?
Best regards
Lolo
These non-dimensional numbers can be defined for any type of numerical discretization but their role in the numerical stability depends on the discretization, from case to case. However, for a steady case you should also consider the Peclet cell number.
FMDenaro is offline   Reply With Quote
Old   June 6, 2020, 06:51
Lennard Porter
ok allright thank you
conduction, courant, heattransfer, peclet number, timestep
Decomposing meshes Tobi OpenFOAM Pre-Processing 22 February 24, 2023 10:23
[mesh manipulation] mergeMeshes for more than two fluid domains Vishsel OpenFOAM Meshing & Mesh Conversion 17 May 20, 2019 08:05
SigFpe when running ANY application in parallel Pj. OpenFOAM Running, Solving & CFD 3 April 23, 2015 15:53
[blockMesh] --> foam fatal error: lillo763 OpenFOAM Meshing & Mesh Conversion 0 March 5, 2014 11:27
Unaligned accesses on IA64 andre OpenFOAM 5 June 23, 2008 11:37
