Error: Couldn't rename the file, another process may be using the file |
May 15, 2020, 08:08 |
MA
Rep Power: 6 |
I ran the simulation on STARCCM+ for a few time-steps, and when I try to save it I get the error "cannot rename the file, another process may be using the file". I looked for it in the userguide, it says that it happens when you don't have "write-access privileges" what is meant by this? |
save data, starccm+ |
[swak4Foam] funkyDoCalc with OF2.3 massflow | NiFl | OpenFOAM Community Contributions | 14 | November 25, 2020 04:30 |
[swak4Foam] Problem installing swak_2.x for OpenFoam-2.4.0 | towanda | OpenFOAM Community Contributions | 6 | September 5, 2015 22:03 |
[swak4Foam] swak4foam building problem | GGerber | OpenFOAM Community Contributions | 54 | April 24, 2015 17:02 |
OpenFOAM on MinGW crosscompiler hosted on Linux | allenzhao | OpenFOAM Installation | 127 | January 30, 2009 20:08 |
DecomposePar links against liblamso0 with OpenMPI | jens_klostermann | OpenFOAM Bugs | 11 | June 28, 2007 18:51 |
