May 12, 2020, 20:57 |
Euler model for drops and liquid film
Karnauhov Valery
Rep Power: 12 |
I'm sorry, I'm using google translate.
I ask for advice on the following question. I solve a problem with a two-phase flow (drops in the steam flow). During the flow, drops fall on the wall and form a liquid film. I use the Euler model with two phases. The secondary phase is a liquid with a drop diameter of 10 microns. My question is, what happens when drops form a film? How to calculate the drag force on the surface of the film? How does the program determine the film surface? I tried the Multi-Fluid VOF Model, but it requires too small a time step. So I want to use the Euler model. Thank you for any recommendations. Last edited by kveki; May 13, 2020 at 11:12. |
euler model, fluent, liquid film, multi-fluid, separate flow |
Wrong flow in ratating domain problem | Sanyo | CFX | 17 | August 15, 2015 06:20 |
Overflow Error in Multiphase Modelling with Two Continuous Fluids | ashtonJ | CFX | 6 | August 11, 2014 14:32 |
VOF - Eliminating shear on the surface of a thin liquid film | saisanthoshm88 | Fluent Multiphase | 0 | October 27, 2013 12:22 |
liquid film model | hobby | OpenFOAM | 1 | May 10, 2010 03:08 |
