PengRobinson floating point exception
Old   May 10, 2020, 12:43
Post PengRobinson floating point exception
Daniel
Dmarcohe is on a distinguished road
Hello CFDler,
i am working on a simulation with fluid CO2 through a diffusor at 60 bar and roomtemepratur. The fluid should pressure driven exit the nozzle.
I started my first simulation with the Equation of state perfectGas which worked. Now i changed the EOS to PengRobinsonGas and now i get a "floating point exception" (division through zero) after a few iterations.
In this link you can find my case with the log File:
https://drive.google.com/open?id=1wv...zqL9c6CEc9YcxU
I already tried to change the Boundarys, the numeric and my mesh without any oblique lines but nothing worked.
Any suggestions?
Greatings
Daniel
Dmarcohe is offline   Reply With Quote
Old   May 11, 2020, 05:34
Eifoehn4's Avatar
Eifoehn4 is on a distinguished road
In most cases, when using real equations of state, the CFD user is not aware that in some areas the setup surpasses the physical limits of the EOS.
I would suggest, to modify your thermodynamic states and approach the initial condition in stages, e.g. reduce your pressure to 1 bar at 293.15 K temperature.
Regards
Check out my side project:
A multiphysics discontinuous Galerkin framework: Youtube, Gitlab.
Eifoehn4 is offline   Reply With Quote
Old   May 11, 2020, 05:40
Daniel
Regards
Thank you. When i change my pressure settings to 2bar the simulations starts and runs. With 8 bar i get the same error but it runs longer.
So you're recommending to increase the pressure on the fly?
Old   May 11, 2020, 06:58
Eifoehn4's Avatar
Not exactly, i mean that you should be aware if your underlying problem may produce non-physical conditions for you geometrical setup.
Independantly of this, a ramping of the boundary or initial conditions is no bad choice.
Regards
Old   May 11, 2020, 07:27
Daniel
Regards
I just tried to ramp my pressure, but for that i had to change the bcs at the inlet. With the new BCs the simulations starts, but doesnt reach the first point i had defined with "table". It ended with the same Error.
cfd - post, equation of state, openfoam 1806, pengrobinsongas
icoFoam floating point exception (8) leizhao512 OpenFOAM Running, Solving & CFD 7 November 1, 2018 12:43
A floating point exception has occurred: floating point exception [Overflow]. starlight STAR-CCM+ 4 May 4, 2016 10:08
A floating point exception - SEM Model yansheng STAR-CCM+ 1 April 4, 2016 05:57
Floating point exception from twoPhaseEulerFoam openfoammaofnepo OpenFOAM Running, Solving & CFD 1 March 19, 2016 14:56
Floating point exception (core dumped) for GAMG solver yuhou1989 OpenFOAM Running, Solving & CFD 2 March 24, 2015 20:28
