estimating surface normals and areas in structured mesh
Old   May 9, 2020, 04:31
Default estimating surface normals and areas in structured mesh
Ashkan Rafiee
cfdwave is on a distinguished road
Hi All,
Sorry if the question might be simple but I have my data on a simple regular grid and am interested to estimate surface normal and area of the geometry to use to do surface integrals. My data structure are slightly specific and I have posted the details here
https://stackoverflow.com/questions/...tructured-grid
I would really appreciate any comments.
Thanks
Ashkan
cfdwave is offline   Reply With Quote
Old   May 9, 2020, 07:08
sbaffini's Avatar
Paolo Lampitella
sbaffini will become famous soon enoughsbaffini will become famous soon enough
Send a message via Skype™ to sbaffini
It seems like you are after a way to compute surface integral within a level-set like immersed boundary approach. There is surely literature on this but I can'trecall any specific paper at the moment. Have you tried searching with more specific keywords?
sbaffini is offline   Reply With Quote
Old   May 9, 2020, 07:21
Ashkan Rafiee
That is absolutely correct Paolo that what I am after is very similar to immersed boundary and I indeed searched with keywords of immersed boundary but could not find anything.
Old   May 9, 2020, 07:36
sbaffini's Avatar
Paolo Lampitella
I work with a different kind of immersed boundary, where surface integrals are straightforward, so this sort of things it's not in my daily routine and I can't recall any specific paper at the moment. But there are literally dozens where the approach is at least similar.
If I had to give you my 2 cents (to be taken with a grain of salt) I would go with:
1) marching cube (square in 2D) algorithm to find the exact intersection for a given, arbitrary, level-set value. Should be quite simple in 2D over a structured grid (https://en.wikipedia.org/wiki/Marching_squares)
2) 1 should give you a set of edges with relative intersected cells, from which you can get the function to be integrated using the correct side. Sum all over the edges (order should be irrelevant) and you should be done
Old   May 9, 2020, 07:46
sbaffini's Avatar
Paolo Lampitella
Of course, this might well be an overkill. You could also just loop on all the cells and once you detect a jump in level set you just need to detect the intersection points (maybe you can use VOF or level set literature for this) and compute the length L of the edge between them (then adding L times n times P in the outer cell to your integral).
Old   May 9, 2020, 09:24
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
is the problem 2D or 3D?
FMDenaro is offline   Reply With Quote
Old   May 9, 2020, 10:19
Ashkan Rafiee
It is 2D but will be expanded to 3D later as well.
Old   May 9, 2020, 13:09
I was thinking about a simple way: in the 3D space a plane is defined by f(x,y,z)=z-a*x-b*y+c=0, where a,b,c can be determined using three nodes that determine a plane surface. The direction of the normal is obtained by the partial derivatives
df/dx=a
df/dy=b
df/dz=1
you can normalize to get the normal vector unit.
finite difference, surface area, surface normals
[snappyHexMesh] High quality mesh for wind in complex urban environment ziboaa OpenFOAM Meshing & Mesh Conversion 1 January 12, 2021 16:33
[snappyHexMesh] snappyHexMesh Boundary Layer at Corner panpanzhong OpenFOAM Meshing & Mesh Conversion 5 July 3, 2018 06:53
[snappyHexMesh] Snappyhex mesh: poor inlet mesh Swagga5aur OpenFOAM Meshing & Mesh Conversion 1 December 3, 2016 17:59
[snappyHexMesh] snappyHexMesh - geometry does not appear in Mesh czhongrong OpenFOAM Meshing & Mesh Conversion 1 January 20, 2016 06:26
[snappyHexMesh] Collapsing Layers Tim_Simon OpenFOAM Meshing & Mesh Conversion 5 August 2, 2015 23:51
