May 6, 2020, 22:08 |
Choosing the Analysis System
Sanjay
Rep Power: 6 |
Dear Friends,
I am trying to make the model of Hot fluid passing with high pressure into the pipe. I would like to know the type of analysis system I can use. I am looking for both Steady-state and Unsteady states too. If I try to model the 2-way FSI then I can also understand the thermal-structural behavior between the hot fluid with high pressure and the structure For unsteady state: Which one is right? a. Fluent b. transient structural c. coupling system or a. Fluent b. thermal transient structural c. Coupling tool |
fluid solid interaction, fluid solid interface |
Specifying Regions in Coupled Fluid-Structural System | tlewis3348 | CFX | 0 | October 17, 2017 08:29 |
Workbench - which analysis system to use? | atyy | ANSYS | 1 | April 20, 2013 10:27 |
Algorithme choosing for solid part analysis of conjugate heat transfer | Anna Tian | Main CFD Forum | 4 | January 20, 2013 16:11 |
Need help with analysis of a small compressor/diffuser system | jkbg38 | FloEFD, FloWorks & FloTHERM | 3 | October 3, 2009 06:44 |
Need ideas-fuel discharge system | Jan | FLUENT | 1 | October 10, 2006 23:05 |
