April 29, 2020, 11:21 |
Natural convection regime in a small cavity
Antonio
Rep Power: 10 |
Hi all.
Trying to study the behavior of a fridge in natural convection regime. I have simplified a lot the problem, to understand if my model works but it seems not to. The cavity is very small 60cmx100cm and the flow is steady. I set up a density based model, activated the energy equation and set up the gravity along the y axes with negative value. I have used a laminar model and a k-omega standard but the results are very poor, although my mesh quality is correct. I am pretty sure that I am missing something in the B.C or reference value. The rear vertical is set with 277 K and zero heat flux. The other three walls are at the same temperature of 300K and thermal insulated as well. I would expect a contour of temperature as evidence of natural convection motion but none of this happened. The model has converged on 10E-5 values of the residuals after 10k iterations. Any help? Thanks in advance for any reply. [IMG] https://ibb.co/Fz6NVLV [/IMG] mesh [IMG] https://ibb.co/gyLbw6y [/IMG] Velocity contours for K-omega standard [IMG] https://ibb.co/Pg5Tp2G [/IMG] Static temperature |
April 29, 2020, 14:45 |
duri
Rep Power: 17 |
Density based approach are good for very low speed flows better use pressure based solver with density as function of temperature (not ideal gas).
natural convection in square cavity without using Boussinesq approximation | rahul62 | OpenFOAM | 0 | February 21, 2018 06:48 |
Natural Convection in Cavity with Cu-Water NanoFluid | Ahmadreza_b | FLUENT | 3 | March 29, 2017 09:35 |
yPlus value in internal flow (natural convection in cavity) | tarunw | OpenFOAM Running, Solving & CFD | 0 | January 26, 2017 10:07 |
Natural convection - Inlet boundary condition | max91 | CFX | 1 | July 29, 2008 21:28 |
Instability at the onset of natural convection | Magherbi | Main CFD Forum | 0 | October 23, 2002 10:53 |
