Calculate Percentage Area Reduction between Damper Blades |
April 29, 2020, 02:27 |
Rob Wilkinson
Rep Power: 6 |
I did a Civil Engineering course some years ago and from my textbook I had a question on damper blades, which is shown in the 2 attached images.
I'm not sure how to solve this question. If someone knows may you please explain to me how I should work this out or at least give me some idea where to start ? https://i.stack.imgur.com/4AMmV.png Last edited by Rob Wilk; April 29, 2020 at 02:34. Reason: Put in IMG tags rather than URL |
April 29, 2020, 04:38 |
Lucky
Rep Power: 66 |
Calculate the boundary layer thickness at the end a 200 mm plate and multiply by 2 (b/c parallel blades). Then figure out what % of the plate separation this corresponds to.
May 1, 2020, 10:21 |
#3 | |
Rob Wilkinson
Rep Power: 6 |
Boundary Layer thickness = 5.48 (Rex)^-0.5 * x^0.5 Boundary Layer thickness = 5.48 (mu / (Rho * velocity))^0.5 * x^0.5 Boundary Layer thickness = 5.48 (0.000018 / (1.18 * 25))^0.5 * 0.2^0.5 Boundary Layer thickness = 0.00191434761 m You say multiply by 2 because there are parallel blades, so we now have 0.0038287 m You then say "figure out what % of the plate separation this corresponds to". What is the plate separation, is it 0.2 * 2 = 0.4 m ? So is this (0.0038287 / 0.4) *100 = 0.957 % The answer is 0.638 % I am out, why is this ? |
May 1, 2020, 15:47 |
Lucky
Rep Power: 66 |
I misread the problem, it's way simpler. I thought the blades were 200 mm long They are not. The plate separation distance is 200 mm. The velocity profile is given. You just need to figure out mean flow thru the gap. Sort of like figuring out the displacement thickness.
If you figure out the correct boundary layer thicknes (the value for delta) and then do a certain integral with the velocity profile you can get the answer in one line. |
May 2, 2020, 10:35 |
#5 | |
Rob Wilkinson
Rep Power: 6 |
Boundary Layer thickness = 5.48 (Rex)^-0.5 * x^0.5 Boundary Layer thickness = 5.48 (mu / (Rho * velocity))^0.5 * x^0.5 Boundary Layer thickness = 5.48 (0.000018 / (1.18 * 25))^0.5 * 0.2^0.5 Boundary Layer thickness = 0.00191434761 m As for the flow through the gap, wouldn't that be the air velocity 25 m/s * 0.2m separation between damper blades * height (what is that) You mentioned you can get answer in one line by doing integral on velocity profile. I don't have a way to show the symbols, but I'll explain So would that be an integral for 2 (y / boundary layer thickness) - (y / boundary layer thickness) ^2 what would y be and what would be the limits for the integral ? Are you able to please clarify these things that I have mentioned ? |
May 3, 2020, 23:01 |
#6 | |
Rob Wilkinson
Rep Power: 6 |
Just wondering if you saw my last reply. Just a few couple of important things to sort out to solve this. |
May 4, 2020, 02:19 |
#7 | |
Rob Wilkinson
Rep Power: 6 |
Are you able to please clarify for me what I have mentioned in my previous reply. |
May 23, 2020, 03:39 |
#8 | |
Rob Wilkinson
Rep Power: 6 |
I just haven't got my head around how this is calculated just yet. You mentioned two ways:
how to calculate the area of a boundary in UDF? | peter | FLUENT | 2 | May 31, 2021 20:54 |
CFX Solver Memory Error | mike | CFX | 1 | March 19, 2008 07:22 |
Can Tecplot calculate isosurface area alon axis x? | leaf | Tecplot | 0 | May 21, 2007 12:20 |
How to calculate circulation area by streamfunctio | John Yee | FLUENT | 0 | July 24, 2006 10:16 |
Calculate volumetric interfacial area | summer | FLUENT | 0 | June 14, 2006 11:46 |
