Open Water Kaplan Propeller Performance Characteristics
Old   April 28, 2020, 04:28
Default Open Water Kaplan Propeller Performance Characteristics
rc4559 is on a distinguished road
I post this question in the main forum as I believe it does not fit any of the other more specific forums here. I am sure some of you will be able to provide insight into my problem.
Introduction:
I am interested in obtaining the open water performance diagrams of fixed pitch Kaplan Ka-series propellers in different nozzle types. By that I mean obtaining the non-dimensional thrust, torque and efficiency parameters (Kt, Kq, Ktn and n) for different advance velocities and rpms. I am using notation from [1] here.
So far, I have been able to obtain the characteristics of Ka365, Ka455, Ka470 and Ka575 for the 19a nozzle, and the Ka470 for the 37 nozzle, from the different tables in [1], [2] and [3].
Unfortunately, I have not been able to find a proper source or database containing data of other propellers of this series, so at this point I am wondering if people use CFD to obtain such parameters (which seems cumbersome, tedious and error prone). I would like to believe that experimental databases should exist by now, so using simulations does not seem appropriate to me for this specific problem. Furthermore, I only have little experience using OpenFOAM, and basic understanding of fluids due to my engineering background.
Questions:
1) Where can this parameters be found/purchased? Which are the main sources for this kind of data?
2) If they can not be purchased or simply do not exist, are you aware of successful CFD analysis of open water propeller performance characteristics? Which trusted references should I check?
Thank you in advance!
References:
[1] Carlton J.S., Marine Propellers and Propulsion 3rd Ed., Elsevier, 2012.
[2] Oosterveld M.W.C., Wake Adapted Ducted Propellers, NSMB Wageningen Publication No. 345, 1970.
[3] Principles of Naval Architecture Vol. II, SNAME, 1988.
rc4559 is offline   Reply With Quote
Old   May 2, 2020, 19:06
Claudio Boezio
Ship Designer is on a distinguished road
you could try and ask Model Basins. If they don't have the information you are looking for, maybe they can point you in the right direction. Apart from that, I'm sure the different manufacturers of azimuth and transverse thrusters have the info, since these are the propellers they use. However I imagine that they are very reluctant to give that type of information away. If you need the info to estimate/calculate propulsive performance, their preferred way is to having them calculate everything for you. If however they see no money in your project (e.g. research, concept design), it's unlikely that they'll help you.
Cheers
Ship Designer is offline   Reply With Quote
kaplan, marine propeller, propeller, propeller thrust
[OpenFOAM.com] swak4foam compiling issues on a cluster saj216 OpenFOAM Installation 5 January 17, 2023 17:05
[Other] Tabulated thermophysicalProperties library chriss85 OpenFOAM Community Contributions 62 October 2, 2022 04:50
[swak4Foam] swak4foam for OpenFOAM 4.0 mnikku OpenFOAM Community Contributions 80 May 17, 2022 09:06
No liquid water exist in my Fuel Cell simulation fatchang FLUENT 19 October 15, 2018 15:27
OpenFOAM with IBM AIX matthias OpenFOAM Installation 20 March 25, 2008 03:36
