Negative volume mesh
Old   April 24, 2020, 14:10
Default Negative volume mesh
Marium Mou
Marium is on a distinguished road
Hello all,
I have been trying to simulate a ship imported mesh from Pointwise to starccm+.
The problem what I am facing now is that after running 40 mins/252 iterations it shows error implying that there is non-positive volume cell 1.jpgand the expanded error message shows reversed flow and matrices problem.2.PNG
I have used the mesh diagnostic before running, it shows the mesh has no negative volume.Capture (1).PNG
I have examined the mesh volume component in pointwise too. And yes it might have a few volumes with a negative value.
Can anybody lead me what is the actual problem and what should I do? I have been stuck with this problem forever and tried to remesh the model a few time. Thanks in advance
Marium is offline   Reply With Quote
Old   April 25, 2020, 23:47
Chris
Chris2337 is on a distinguished road
I cant imagine needing to run 252 iterations to get this kind of error or notice something seems wrong. What I can say is I've had issues going from Pointwise to Star before and it could be something you setup the Pointwise mesh to be all negative volume in Star's mind. I saw someone flip this in Fluent so you can problem do that in Star.
Chris2337 is offline   Reply With Quote
Old   April 28, 2020, 01:56
Marium Mou
sorry I didn't get your word. The mesh report in star does not show any negative cells. what else the problem could be? it happens after every 252 iterations- reversed flow and matrices problem. I have not solved the problem yet!
starccm+, volume cell
[Other] mesh airfoil NACA0012 anand_30 OpenFOAM Meshing & Mesh Conversion 13 March 7, 2022 18:22
[ANSYS Meshing] Small mesh error: Zero or negative volume for elements. [Explicit dynamics] matin ANSYS Meshing & Geometry 0 September 14, 2017 21:19
snappyhexmesh remove blockmesh geometry philipp1 OpenFOAM Running, Solving & CFD 2 December 12, 2014 11:58
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 07:20
[blockMesh] non-orthogonal faces and incorrect orientation? nennbs OpenFOAM Meshing & Mesh Conversion 7 April 17, 2013 06:42
