Why residuals are jumped to a high value after being steady and monitor plot experien
Old   April 22, 2020, 09:44
Default Why residuals are jumped to a high value after being steady and monitor plot experien
MA
mazhar16823 is on a distinguished road
I ran the simulation while using SST Transition model in STARCCM+ with following settings:
Free stream edge function for SST Transition Model = $WallDistance>0.005?1:0
I made following selections in physics continua:
All y+ Treatment
Gamma Re-Theta Transition
Constant Density
Segregated flow
Steady
SST (Menter) K-Omega
3D
Turbulent
In initial conditions, I changed the incoming flow velocity= -9 m/s.
In Reports>Drag Coefficient: Direction (0, 0, 1) because inflow is in z-direction and in coordinate system z-axis is pointing opposite to the flow direction.
Reference velocity= -9 m/s,
Reference Area = frontal area for the blade calculated in Report
REGIONS:
Inner Geometry (Blade) => Boundary Type = Wall; Reference Frame: Lab Frame (same for other boundaries)
Velocity Inlet: Flow Direction: [0,0,-1]
With all this monitor plot for the Drag Coefficient experiences small increasing oscillations and residuals also jump after decreasing for a while.
Any suggestions please? What could go wrong?
mazhar16823 is offline   Reply With Quote
Old   April 22, 2020, 09:47
MA
Originally Posted by mazhar16823 View Post
All y+ Treatment
Constant Density
Segregated flow
Steady
3D
Turbulent
REGIONS:
https://drive.google.com/file/d/1EjH...ew?usp=sharing
