April 17, 2020, 23:14 |
Wall Adhesion in DPM
m.reza
Rep Power: 15 |
Hi. I was wondering to know the reason that there is no option to activate Wall Adhesion in DPM.
April 18, 2020, 23:36 |
Lucky
Rep Power: 66 |
First, tell us what software you are using.
April 18, 2020, 23:50 |
m.reza
Rep Power: 15 |
April 19, 2020, 05:07 |
Lucky
Rep Power: 66 |
What were you planning to do with wall adhesion?
DPM has its own BC type inputs which you find in the DPM tab. The D in DPM means Discrete, the VOF-based wall adhesion option isn't compatible with this approach. |
April 20, 2020, 01:36 |
m.reza
Rep Power: 15 |
I think I should use Reflect condition for adhesion of walls.
dpm, wall adhesion |
What's the problem with turbulence models near the wall region? | Jaydi_21 | Main CFD Forum | 6 | July 7, 2017 02:39 |
Basic Nozzle-Expander Design | karmavatar | CFX | 20 | March 20, 2016 08:44 |
[mesh manipulation] mergeMeshes problem | Attesz | OpenFOAM Meshing & Mesh Conversion | 3 | July 29, 2015 04:15 |
[Commercial meshers] tmerge utility creates unwanted interface/walls comes in the final mesh | Shoonya | OpenFOAM Meshing & Mesh Conversion | 11 | January 20, 2012 06:23 |
angle for wall adhesion in two phase flow | Al-jasim | FLUENT | 0 | August 18, 2007 10:04 |
