Rep Power: 10 ![]() |
I am wondering when I can simplify the Navier-Stokes Equations and just use the Euler Equations in CFD? Euler: Navier-Stokes for inviscid flow Reynolds number= ratio of inertial forces / viscous forces So to my understanding, for really high reynolds numbers, the viscous forces decrease, so we can use the euler equations. On the other hand: when we have high reynolds numbers, the flow is turbulent, where friction/viscous forces play an important role (I assume). I read that Euler can be used for high Mach Numbers, where the shock wave influence plays a more important role than the viscous forces. So for high Mach numbers also the reynolds numbers increase. Could someone bring light into my darkness? To which limits would you use Euler for calculations? Thanks! CellZone |
#2 | |
Filippo Maria Denaro
Rep Power: 73 ![]() ![]() ![]() |
Euler equations are a mathematical model that does not allow to set a physical condition about the tangential velocity. Furthermore, the physical energy dissipation is not present and the captare of a real shock wave requires care. High Re number flows are still governed by the NSE, you can see that as the perturbed form of the Euler equations. If you need details about the dynamic and thermal BL you cannot use Euler. |
Attached, high Re number, external aerodynamic flows is what comes first to my mind.
Everything where the inviscid pressure effects are orders of magnitude higher than viscous ones might be a good rule of thumb (maybe blasts, etc.) |
#4 | |
Lucky
Rep Power: 66 ![]() ![]() ![]() |
The viscous forces don't decrease, they're still increasing. They're just increasing slower than the inertial force. Even if you take the limit as viscosity goes to zero, you have non-zero viscous dissipation because the velocity gradients can increase without bound. |
Rep Power: 14 ![]() |
First of all you should be aware that the difference between Euler and Navier-Stokes equations is not only viscosity.
In most cases it is useful to define the terms you want to talk about, e.g., what exactly do you mean when your are talking about Euler and Navier-Stokes equations. The classical Navier-Stokes equations consists of at least two different parabolic effects, heat conduction according to Fouriers law and viscous effects according to Stokes law. If you play with more general physics you have to consider more parabolic effects, e.g. Fickian law for multi-species or combustion. |
#6 | |
Thanks to the rest! |
#7 | |
No matter how much you talk about Reynolds or Mach number number, if you don't mention your application a advice is meaningless. Consider fuel injection or multi-phase flows. Here, i would not recommend to run a simulations only with the Euler equations, even if viscous effects are small enough. Other physical effects, e.g. heat conduction, are here far more important. Your question is too general for a simple answer. Last edited by Eifoehn4; April 22, 2020 at 00:50. |
#8 | |
What I learned in school (maybe I did not pay enough attention) is that Euler=Navier Stokes + zero viscosity... Never heard from conductivity ... makes me confused |
#9 | |
dE/dt= W - Q In order to have a reversible transfer of energy you need zero heat flux and the only reversibile part of the mechanical work. That is no viscosity and no conducibility |
Incompressible Euler Equations with SIMPLE method | yfjok22 | OpenFOAM Programming & Development | 1 | September 22, 2016 08:11 |
SU2 in Euler form coupled with BL equations | francescofaggiano | SU2 | 0 | May 4, 2016 04:05 |
Normalization of eigenvectors of the Euler equations | bubble45 | Main CFD Forum | 9 | March 16, 2015 17:09 |
Euler equations | besh | Main CFD Forum | 1 | September 3, 2013 13:26 |
Math. nature of incompressible Euler equations | Florian Longueteau | Main CFD Forum | 14 | July 10, 2007 15:55 |
