Airflow velocity fluctuation with iteration
Old   April 15, 2020, 06:44
Default Airflow velocity fluctuation with iteration
JSH
jshjsh is on a distinguished road
Hi!
Recently,I have noticed a simple problem about indoor airflow steady-state simulation. I found that monitored point or surface velocity magnitude is difficult to converge (become stable). The velocity magnitude always irregularly changes with the iteration, or it can be "slightly" stable for a long iteration time, though mass balance, heat balance or temperature monitor can achieve fast convergence. In many cases, my physical model of the room is very simple and the mesh quality is not low,the problem still exists. I don't know if this is a common problem in indoor air flow simulation? Or did I set something wrong? can anyone give me some advices?
*Unstructured grid
*Fluent Pressure-Based solver
*Steady-state
*Standard k-e model and Standard wall function
*One velocity-inlet and one outflow/pressure-outlet
*Others keep the default
jshjsh is offline   Reply With Quote
indoor air, velocity change, velocity convergence, velocity fluctuation
kindly help me .. i have and error at line number 147.. m zubair Fluent UDF and Scheme Programming 0 February 10, 2019 12:25
Shear Velocity in SimpleFoam iteration chusma OpenFOAM Programming & Development 0 July 21, 2017 08:02
3D velocity fluctuation profiles from a file in initialization section using LES. Aramisss CFX 0 July 8, 2015 17:24
Hardware-Configuration for Fluent HPC-Pack (8x) JohHaas Hardware 9 March 3, 2015 14:25
how to calculate rms velocity fluctuation after runtime nati OpenFOAM Post-Processing 6 February 7, 2013 09:42
