Air Bubble
Old   March 27, 2020, 09:19
Default Air Bubble
Giuseppe
pezarello86 is on a distinguished road
i am involved in a R&D project on bubble curtains.
First of all i want to validate the methodology to create the air bubble and especially the velocity field inducedny the bubble rising.
I found different papers and about this topic i found also the experimental results.
The model is made of a rectangulare domain with an airbubble at the bottom (slightly above the bottom) in a quiescent water: the bubble rise to buoyancy force.
the setup of simulations a multiphase model: VOF+Level set functions. I am using the same setup of the paper and my proble is aùhow to recognise the uprise velocity of air bubble because the bubble breaks.
Does someone can help me?
Thank you very much
pezarello86 is offline   Reply With Quote
Old   March 27, 2020, 12:50
Default Help
vinerm's Avatar
Vinerm
vinerm will become famous soon enough
You have not mentioned what help do you require? Do you need help with setup or with convergence or something else?
Regards,
Vinerm
PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority.
vinerm is offline   Reply With Quote
Old   March 30, 2020, 09:11
Giuseppe
Sorry you are right.
By the way i solved by myself.
thank you again and fro the next time i will try to be more accurate on what kinf of help i need
bubble, fluent, vof, vof method
Bubble Collapse Simulation in STAR-CCM+ JM27 STAR-CCM+ 3 January 2, 2023 06:21
Outlet : Air freeboard region Bubble column sarrazs CFX 7 October 28, 2017 07:16
air headspace in bubble column sarrazs CFX 1 October 19, 2017 19:19
CFX bubble simulation with free surface model adma CFX 6 February 3, 2006 12:17
Help!!!problems in air jet into water bath kim FLUENT 4 June 9, 2003 08:04
