March 20, 2020, 06:44 |
Spectral analysis on triangular meshes
Rep Power: 8 |
Is there any existing literature on spectral analysis of numerical schemes on triangular meshes?
March 20, 2020, 11:46 |
Rep Power: 14 |
Dear shalabhks,
you may apply your spectral analysis after swapping your data from the triangle to a cartesian background mesh via interpolation or projection. If your solution is smooth enough this should work. Generally a spectral analysis also depends on your solution representation. What numerics do you use for your results? |
March 20, 2020, 13:47 |
Filippo Maria Denaro
Rep Power: 73 |
If you google in internet there are references. Interpolation of data on equidistant nodes is a rude way on high wavenumber components and can produce large error. I suggest also to search on this site for some hints
https://people.maths.ox.ac.uk/trefethen/ |
March 21, 2020, 01:16 |
"spectral analysis of numerical schemes" seems to imply von-neumann analysis to study stability and dispersion/dissipation properties of the numerical scheme. Is this what you are asking ? If yes, then I think there is not much option that I am aware of, since this type of analysis requires cartesian grids.
March 21, 2020, 22:59 |
Rep Power: 8 |
Thank you. I am using JST scheme.
numerical schemes, spectral analysis, triangular mesh |
How to implement a sensitivity analysis for certain items | Mason liu | CFX | 10 | August 17, 2017 08:46 |
How can I put the data of adpated meshes on the original unadapted meshes? | xh110120 | FLUENT | 2 | March 11, 2016 02:00 |
Structural Analysis on a (large) Triangular Mesh Based on 3D Laser Scan | frist | Structural Mechanics | 0 | February 5, 2016 16:15 |
Hex and Tet meshes - simplefoam comparison | danvica | OpenFOAM Running, Solving & CFD | 10 | January 4, 2013 01:18 |
Spectral Vs FEM | Khurram | Main CFD Forum | 0 | December 15, 2002 17:33 |
