February 29, 2020, 18:56 |
Polyurethane foaming simulation
Sebastian Guaqueta
Rep Power: 6 |
Good day my fiends,
I am starting an academical project based on the simulation of the foaming process of Polyurethane in a rectangular plate (12 m X 1 m x 0.05 m), on OpenFoam. This involves change of phase from liquid to solid, I got experimental data about the change of density over time (given from manufacturer) and I want to try simulate different nozzle geometries and research the implication of these geometries on the final foaming. My idea, is to attack initially the solver issue with a straight nozzle by appliyng the experimental data. Maybe someone here had worked with this kind of solvers before? I have checked paper's In scientific databases, and I found some information which I'm taking for starting, anyway some clues could be helpful for me. Thanks you all a lot . |
foaming, multiphase flow, openfoam, polyurethane, thermal insulation |
Convergence Problem - Transient Simulation | gemxx | Main CFD Forum | 0 | July 15, 2018 10:36 |
Mapping Field Data for Mesh Regions from Another Simulation | veterator | OpenFOAM Pre-Processing | 1 | July 10, 2018 06:28 |
Surface Source - Fixed Temperature? | robtheslob | FloEFD, FloWorks & FloTHERM | 18 | May 12, 2017 03:28 |
Simulation FPEs - turbulence for transient and steady-state? | DaveR | OpenFOAM Running, Solving & CFD | 5 | March 5, 2017 16:06 |
Simulation of high pressure diesel injector - all phases compressible with cavitation | fivos | CFX | 4 | July 30, 2015 07:48 |
