February 25, 2020, 15:34 |
AVL: Chordwise Panel Spacing Help
I am using AVL to compare lift coefficient calculations against a Vortex Lattice program I have written. The input AVL file is attached (you will need to change the file extension from .txt to .avl if you wish to run it). I am looking to generate 10, equally-spaced, spanwise panels and 4, equally-spaced, chordwise panels. Spanwise looks good, however, when I follow the AVL documentation to produce this result, I get strange chordwise panel spacing (see pic below). As far as AVL lift calculations go, they are similar to what I predicted with my code, but AVL seems to be about 10% greater lift coefficients across the span. https://imgur.com/a/HQCdfvJ I defined Nchord as 4, with Cspace as 0 (which should correspond to uniform chordwise spacing). Is there a way to get the chordwise panels to be "truly" uniform like the spanwise panels are? Or is this just an AVL thing that will not affect lift calculations? |
March 3, 2020, 01:10 |
In case anyone ever comes across this post with the same question:
The purple lines represent the boundaries of the horse-shoe vortex structures, which are offset by the quarter-chord in each panel, hence the strange panel spacing. The image shown does actually use 5 equally spaced, span-wise panels and 4 equally spaced, chord-wise panels. |
Vortex Panel Method | Rafaelle55 | Main CFD Forum | 1 | December 17, 2018 11:16 |
'Spacing Constraints' greyed out in "List" panel of Pointwise | cfd335 | Pointwise & Gridgen | 1 | November 9, 2018 12:14 |
[Pointwise] Problem in spacing constraints | ian0103 | Pointwise & Gridgen | 2 | December 29, 2016 22:18 |
3D PANEL METHOD | Paolo Lampitella | Main CFD Forum | 12 | August 27, 2014 12:46 |
[ICEM] Equal Spacing on all the edges | Tarantino | ANSYS Meshing & Geometry | 6 | March 15, 2013 14:13 |
