OpenFOAM error
Old   February 20, 2020, 10:17
Default OpenFOAM error
Vinay Kumar V
Vinay Kumar V is on a distinguished road
I have created a mesh in Gmsh and imported into OpenFOAM. I got 'Unhandled element 1 at line ....' FATAL ERROR as '2 not found in table'
Unhandled element 1 at line 129081
Unhandled element 1 at line 129082
Unhandled element 1 at line 129083
Unhandled element 1 at line 129084
Unhandled element 1 at line 129085
Unhandled element 1 at line 129086
Unhandled element 1 at line 129087
Unhandled element 1 at line 129088
Unhandled element 1 at line 129089
Unhandled element 1 at line 129090
Unhandled element 1 at line 129091
Unhandled element 1 at line 129092
Unhandled element 1 at line 129093
--> FOAM FATAL ERROR:
2 not found in table. Valid entries: 0()
From function const T& Foam::HashTable<T, Key, Hash>:perator[](const Key&) const [with T = int; Key = int; Hash = Foam::Hash<int>]
in file /opt/app/OpenFOAM/OpenFOAM-dev/src/OpenFOAM/lnInclude/HashTableI.H at line 126.
FOAM exiting
In gmsh, I do not have errors.
[CODE][// Gmsh project created on Wed Feb 19 13:48:09 2020
SetFactory("OpenCASCADE");
Rectangle(1) = {0.21, 0.13, 0.2, 0.5, 0.5, 0};
Rectangle(2) = {-2.1, -2.2, -2, 5, 5, 0};
Rectangle(3) = {-0.35, -0.35, -0.5, 1.5, 1.5, 0};
Extrude {0, 0, 0.5} {
Surface{1};
Extrude {0, 0, 5} {
Surface{2};
BooleanDifference{ Volume{2}; Delete; }{ Volume{1}; Delete; }
Extrude {0, 0, 2} {
Surface{3};
Line(41) = {12, 4};
Line(42) = {1, 9};
Line(43) = {3, 11};
Line(44) = {2, 10};
Line(45) = {13, 25};
Line(46) = {16, 28};
Line(47) = {15, 27};
Line(48) = {14, 26};
Curve Loop(20) = {42, 33, -45, -13};
Plane Surface(20) = {20};
Curve Loop(21) = {42, -12, 41, 4};
Plane Surface(21) = {21};
Curve Loop(22) = {41, 18, 46, -38};
Plane Surface(22) = {22};
Curve Loop(23) = {45, -40, -46, 20};
Plane Surface(23) = {23};
Transfinite Surface {21} = {4, 1, 9, 12};
Transfinite Surface {22} = {4, 12, 28, 16};
Transfinite Surface {23} = {25, 28, 16, 13};
Transfinite Surface {7} = {1, 4, 16, 13};
Transfinite Curve {20, 40, 4, 12} = 20 Using Progression 1;
Transfinite Curve {13, 33, 18, 38} = 20 Using Progression 1;
Surface Loop(2) = {18, 20, 21, 22, 23, 7};
Volume(4) = {2};
Curve Loop(26) = {42, 9, -44, -1};
Plane Surface(26) = {26};
Curve Loop(27) = {44, 34, -48, -14};
Plane Surface(27) = {27};
Curve Loop(28) = {15, 48, -35, -45};
Plane Surface(28) = {28};
Surface Loop(3) = {4, 28, 27, 26, 20, 15};
Volume(5) = {3};
Transfinite Surface {26} = {1, 2, 10, 9};
Transfinite Surface {27} = {14, 26, 10, 2};
Transfinite Surface {28} = {13, 25, 26, 14};
Transfinite Surface {4} = {13, 14, 2, 1};
Transfinite Curve {9, 1, 15, 35} = 20 Using Progression 1;
Transfinite Curve {13, 33, 14, 34} = 20 Using Progression 1;
// Transfinite Volume{4} = {1, 4, 16, 13, 25, 9, 12, 28};
// Transfinite Volume{5} = {13, 14, 2, 1, 25, 26, 10, 9};
Curve Loop(32) = {44, 10, -43, -2};
Plane Surface(31) = {32};
Curve Loop(33) = {16, 47, -36, -43};
Plane Surface(32) = {33};
Curve Loop(34) = {17, 47, -37, -48};
Plane Surface(33) = {34};
Surface Loop(4) = {31, 32, 33, 5, 27, 16};
Volume(6) = {4};
Transfinite Surface {31} = {2, 3, 11, 10};
Transfinite Surface {32} = {3, 15, 27, 11};
Transfinite Surface {33} = {14, 26, 27, 15};
Transfinite Surface {5} = {14, 15, 3, 2};
//Transfinite Volume{6} = {2, 3, 15, 14, 26, 27, 11, 10};
Transfinite Curve {10, 2, 17, 37} = 20 Using Progression 1;
Transfinite Curve {14, 34, 16, 36} = 20 Using Progression 1;
Transfinite Curve {41} = 40 Using Progression 0.8;
Transfinite Curve {42} = 40 Using Progression 1.2;
Transfinite Curve {43} = 40 Using Progression 1.2;
Transfinite Curve {44} = 40 Using Progression 1.2;
Transfinite Curve {45} = 40 Using Progression 1.2;
Transfinite Curve {46} = 40 Using Progression 1.2;
Transfinite Curve {47} = 40 Using Progression 1.2;
Transfinite Curve {48} = 40 Using Progression 1.2;
Curve Loop(38) = {43, 11, 41, -3};
Plane Surface(36) = {38};
Curve Loop(39) = {47, 39, -46, -19};
Plane Surface(37) = {39};
Surface Loop(5) = {36, 6, 22, 37, 32, 17};
Volume(7) = {5};
Transfinite Surface {36} = {3, 4, 12, 11};
Transfinite Surface {6} = {15, 16, 4, 3};
Transfinite Surface {37} = {15, 27, 28, 16};
Transfinite Curve {3, 19, 39, 11} = 20 Using Progression 1;
Transfinite Curve {16, 36, 18, 38} = 20 Using Progression 1;
// Transfinite Volume{7} = {15, 16, 4, 3, 27, 28, 12, 11};
Surface Loop(6) = {3, 26, 31, 21, 1, 36};
Volume(8) = {6};
Surface Loop(7) = {28, 8, 33, 23, 37, 19};
Volume(9) = {7};
Transfinite Surface {19} = {26, 25, 28, 27};
Transfinite Surface {8} = {14, 13, 16, 15};
Transfinite Surface {1} = {2, 1, 4, 3};
Transfinite Volume{9} = {26, 25, 28, 27, 14, 13, 16, 15};
//Point(29) = {-2.1, 1.2, 1.5, 1.0};
//Point(30) = {-2.1, 1.2, -0.5, 1.0};
//Point(31) = {-2.1, -0.35, 1.5, 1.0};
//Point(32) = {-2.1, -0.35, -0.5, 1.0};
Line(49) = {12, 21};
Line(50) = {28, 22};
Line(51) = {25, 18};
Line(52) = {9, 17};
Line(53) = {11, 23};
Line(54) = {27, 24};
Line(55) = {26, 20};
Line(56) = {10, 19};
Curve Loop(42) = {27, -51, -40, 50};
Plane Surface(40) = {42};
Curve Loop(44) = {21, -51, -33, 52};
Plane Surface(41) = {44};
Curve Loop(46) = {52, -26, -49, 12};
Plane Surface(42) = {46};
Curve Loop(47) = {49, -31, -53, 11};
Plane Surface(43) = {47};
Curve Loop(48) = {52, 23, -56, -9};
Plane Surface(44) = {48};
Curve Loop(49) = {56, 29, -53, -10};
Plane Surface(45) = {49};
Curve Loop(50) = {22, -55, -34, 56};
Plane Surface(46) = {50};
Curve Loop(51) = {55, 30, -54, -37};
Plane Surface(47) = {51};
Curve Loop(52) = {54, -28, -53, 36};
Plane Surface(48) = {52};
Curve Loop(53) = {51, 24, -55, -35};
Plane Surface(49) = {53};
Curve Loop(54) = {50, -32, -54, 39};
Plane Surface(50) = {54};
Curve Loop(55) = {38, 50, -25, -49};
Plane Surface(51) = {55};
Transfinite Surface {41} = {9, 25, 18, 17};
Transfinite Surface {42} = {21, 12, 9, 17};
Transfinite Surface {40} = {22, 28, 25, 18};
Transfinite Surface {51} = {21, 12, 28, 22};
Transfinite Surface {18} = {12, 28, 25, 9};
Transfinite Surface {10} = {21, 22, 18, 17};
Transfinite Curve {21, 33, 38, 25} = 20 Using Progression 1;
Transfinite Curve {27, 40, 26, 12} = 20 Using Progression 1;
Transfinite Curve {52} = 20 Using Progression 1;
Transfinite Curve {51} = 20 Using Progression 1;
Transfinite Curve {50} = 20 Using Progression 1;
Transfinite Curve {49} = 20 Using Progression 1;
Transfinite Surface {49} = {25, 26, 20, 18};
Transfinite Surface {50} = {22, 24, 27, 28};
Transfinite Surface {13} = {22, 24, 20, 18};
Transfinite Surface {47} = {24, 27, 26, 20};
Transfinite Curve {24, 35, 39, 32} = 20 Using Progression 1;
Transfinite Curve {30, 37, 40, 27} = 20 Using Progression 1;
Transfinite Curve {54} = 20 Using Progression 1;
Transfinite Curve {55} = 20 Using Progression 1;
Transfinite Surface {46} = {26, 10, 19, 20};
Transfinite Surface {16} = {27, 11, 10, 26};
Transfinite Surface {48} = {27, 11, 23, 24};
Transfinite Surface {11} = {24, 23, 19, 20};
Transfinite Surface {45} = {11, 23, 19, 10};
Transfinite Curve {22, 34, 36, 28} = 20 Using Progression 1;
Transfinite Curve {29, 10, 37, 30} = 20 Using Progression 1;
Transfinite Curve {56} = 20 Using Progression 1;
Transfinite Curve {53} = 20 Using Progression 1;
Transfinite Surface {44} = {10, 9, 17, 19};
Transfinite Surface {3} = {11, 12, 9, 10};
Transfinite Surface {43} = {11, 12, 21, 23};
Transfinite Surface {12} = {23, 21, 17, 19};
Transfinite Curve {23, 9, 11, 31} = 20 Using Progression 1;
Transfinite Curve {26, 12, 10, 29} = 20 Using Progression 1;
Transfinite Surface {9} = {19, 20, 18, 17};
Transfinite Surface {15} = {10, 9, 25, 26};
Transfinite Surface {17} = {11, 27, 28, 12};
Transfinite Surface {14} = {23, 24, 22, 21};
Recombine Surface {41, 18, 40, 42, 51, 10};
Recombine Surface {40, 19, 49, 13, 47, 50};
Recombine Surface {16, 47, 46, 11, 45, 48};
Recombine Surface {12, 44, 45, 3, 42, 43};
Recombine Surface {15, 46, 44, 49, 41, 9};
Recombine Surface {14, 51, 17, 43, 48, 50};
Recombine Surface {19, 28, 8, 33, 23, 37};
Recombine Surface {5, 27, 33, 31, 16, 32};
Recombine Surface {3, 26, 1, 31, 36, 21};
Recombine Surface {20, 7, 21, 23, 18, 22};
Recombine Surface {6, 32, 37, 22, 36, 17};
Recombine Surface {15, 20, 26, 28, 27, 4};
Transfinite Volume{8} = {1, 4, 3, 2, 9, 12, 11, 10};
Transfinite Volume{7} = {16, 4, 3, 15, 28, 12, 11, 27};
Transfinite Volume{6} = {14, 2, 3, 15, 26, 10, 11, 27};
Transfinite Surface {39} = {11, 27, 28, 12};
Transfinite Surface {38} = {4, 3, 15, 16};
Recombine Surface {39, 22, 36, 32, 37, 38};
Transfinite Surface {34} = {3, 15, 14, 2};
Transfinite Surface {35} = {10, 26, 27, 11};
Recombine Surface {34, 33, 32, 31, 27, 35};
Transfinite Surface {30} = {9, 25, 26, 10};
Transfinite Surface {29} = {2, 14, 13, 1};
Recombine Surface {29, 26, 27, 28, 20, 30};
Transfinite Surface {24} = {12, 28, 25, 9};
Transfinite Surface {25} = {4, 16, 13, 1};
Recursive Delete {
Volume{3};
Recursive Delete {
Volume{2};
Curve Loop(56) = {26, 21, -27, -25};
Plane Surface(52) = {56};
Surface Loop(8) = {52, 42, 41, 40, 51, 24};
Volume(10) = {8};
Transfinite Surface {52} = {21, 22, 18, 17};
Transfinite Volume{10} = {21, 22, 18, 17, 12, 28, 25, 9};
Recombine Surface {52, 42, 41, 40, 24, 51};
Curve Loop(57) = {27, 24, 30, 32};
Plane Surface(53) = {57};
Surface Loop(9) = {53, 49, 47, 50, 19, 40};
Volume(11) = {9};
Transfinite Surface {53} = {22, 24, 20, 18};
Transfinite Volume{11} = {22, 24, 20, 18, 28, 27, 26, 25};
Recombine Surface {53, 40, 49, 47, 19, 50};
Curve Loop(59) = {26, 23, 29, 31};
Plane Surface(54) = {59};
Surface Loop(10) = {54, 44, 45, 43, 3, 42};
Volume(12) = {10};
Transfinite Surface {54} = {17, 19, 23, 21};
Transfinite Volume{12} = {17, 19, 23, 21, 9, 10, 11, 12};
Recombine Surface {54, 42, 3, 44, 43, 45};
Curve Loop(60) = {29, 28, -30, -22};
Plane Surface(55) = {60};
Surface Loop(11) = {55, 48, 46, 45, 35, 47};
Volume(13) = {11};
Transfinite Surface {55} = {19, 20, 24, 23};
Transfinite Volume{13} = {19, 20, 24, 23, 10, 26, 27, 11};
Recombine Surface {55, 45, 46, 35, 48, 47};
Curve Loop(61) = {32, -25, -31, 28};
Plane Surface(56) = {61};
Surface Loop(12) = {56, 50, 39, 48, 43, 51};
Volume(14) = {12};
Transfinite Surface {56} = {22, 21, 23, 24};
Transfinite Volume{14} = {22, 21, 23, 24, 28, 12, 11, 27};
Recombine Surface {56, 50, 39, 51, 43, 48};
Curve Loop(62) = {23, 22, -24, -21};
Plane Surface(57) = {62};
Surface Loop(13) = {57, 44, 30, 46, 49, 41};
Volume(15) = {13};
Transfinite Surface {57} = {17, 18, 20, 19};
Transfinite Volume{15} = {17, 18, 20, 19, 9, 25, 26, 10};
Recombine Surface {57, 44, 46, 49, 41, 30};
Recursive Delete {
Surface{20};
Transfinite Surface {20} = {9, 25, 13, 1};
Recombine Surface {20, 23, 24, 21, 22, 25};
Transfinite Volume{4} = {1, 4, 16, 13, 12, 28, 25, 9};
Recombine Surface {21, 20, 25, 24, 23, 22};
Recursive Delete {
Volume{4};
Curve Loop(63) = {4, 13, -20, -18};
Plane Surface(58) = {63};
Surface Loop(14) = {58, 22, 24, 23, 20, 21};
Volume(16) = {14};
Transfinite Surface {58} = {4, 16, 13, 1};
Transfinite Volume{16} = {4, 16, 13, 1, 12, 28, 25, 9};
Recombine Surface {24, 22, 23, 20, 58, 21};
Recursive Delete {
Volume{5};
Curve Loop(64) = {15, -14, -1, 13};
Plane Surface(59) = {64};
Surface Loop(15) = {59, 26, 20, 28, 30, 27};
Volume(17) = {15};
Transfinite Surface {59} = {13, 1, 2, 14};
Transfinite Volume{17} = {13, 1, 2, 14, 25, 9, 10, 26};
Recombine Surface {59, 30, 20, 26, 27, 28};
Recursive Delete {
Surface{59};
Physical Surface("inlet") = {56};
Physical Surface("outlet") = {57};
Physical Surface("outer_wall") = {52, 54, 55, 53};
Physical Surface("inner_wall") = {8, 38, 1, 59, 34, 58};
Physical Surface("fluid") = {49, 47, 40, 50, 19, 28, 33, 23, 37, 27, 20, 32, 30, 26, 46, 35, 31, 22, 24, 21, 39, 3, 36, 41, 44, 45, 48, 51, 42, 43};
Mesh 3;
Does anyone experienced similar type of error?
Best regards
Vinay
Vinay Kumar V is offline   Reply With Quote
gmsh 4.0.4, open foam fatal error
[blockMesh] blockMesh with double grading. spwater OpenFOAM Meshing & Mesh Conversion 92 January 12, 2019 10:00
long error when using make-install SU2_AD. tomp1993 SU2 Installation 3 March 17, 2018 07:25
Mesquite - Adaptive mesh refinement / coarsening? philippose OpenFOAM Running, Solving & CFD 94 January 27, 2016 10:40
[swak4Foam] groovyBC: problems compiling: "flex: not found" and "undefined reference to ..." sega OpenFOAM Community Contributions 12 February 17, 2010 10:30
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 21:50
