How is drag oscillations past a circular cylinder characterized? |
February 20, 2020, 05:59 |
filippo zacchei
Rep Power: 6 |
Hi guys,
I simulated the flow past a circular isolated cylinder using U-RANS simulation with PHOENICS program (Re=10^4). My object was studying the oscillation of the drag force and Drag coefficient on the cylinder. I appreciated the fact that the oscillations are characterized by a frequency 2 times bigger than the lift oscillations one. However I do not understand why these oscillations, as in the figure, are charcterized by another intrinsic frequency which gives me the altenations of two average minima. I expect that the amplitude differs a little bit, but I don't understand why this pattern is so repetitive also for much longer simulations. Thank you very much Filippo https://ibb.co/jv9Fwbh |
February 20, 2020, 06:50 |
Filippo Maria Denaro
Rep Power: 73 |
Why are you so surprised by the fact that you do not see a singular frequency? Only for a laminar vortex shedding you get an oscillation at a single wavenumber
February 20, 2020, 07:15 |
filippo zacchei
Rep Power: 6 |
Yes that's true. However can you tell me a reason for this seond dominant frequency? It looks like the vortex from one of the side of the cylinder is Always bigger than the other.
February 20, 2020, 07:35 |
#4 | |
Rep Power: 73 |
Are you solving the 3d problem? |
February 20, 2020, 07:47 |
filippo zacchei
Rep Power: 6 |
February 20, 2020, 08:10 |
Rep Power: 73 |
February 20, 2020, 08:58 |
filippo zacchei
Rep Power: 6 |
Actually the only task of my work was to see the shedding vortex behind the cylinder, and comparing it with lift and drag oscillations. However looking at the drag coefficient in the picture we can see the presence of two frequencies. I didn't know if there was a possible explanation to the alternations of the two averages minima. I agree with you that this is not a real and physical problem, since it's 2D. But maybe as using this approximation we can see the oscillation in the drag due to the vortex shedding behind the cylinder, also the presence of different peaks can be related to a reason I can't find at the moment.
February 20, 2020, 09:58 |
Rep Power: 73 |
Have a look to the first part of this paper
https://www.researchgate.net/publica...LIKE_BEHAVIOUR |
February 20, 2020, 15:01 |
#9 | |
filippo zacchei
Rep Power: 6 |
circular cylinder, drag, vortex shedding frequency |
flow over a cylinder urgent! | kevin | FLUENT | 8 | August 11, 2015 13:00 |
How to calculate the drag coefficient for flow past cylinder | o_mars_2010 | Tecplot | 0 | April 18, 2013 01:26 |
FLUENT, flow past a circular cylinder | Paul Reichl | Main CFD Forum | 16 | December 8, 2012 15:21 |
About drag coefficient of 2D circular cylinder! | Haoyin Shan | FLUENT | 0 | May 6, 2007 23:50 |
Simulation of the Flow past a circular cylinder using STAR-CD | M. S. GUEROUACHE | Main CFD Forum | 0 | October 1, 1998 10:51 |
