GMSH 4.5.2: Prism Layer creation (3D boundary layer on 2D face))
Old   February 19, 2020, 10:21
Default GMSH 4.5.2: Prism Layer creation (3D boundary layer on 2D face))
Thomas Enzinger
ThomasEnzinger is on a distinguished road
with 2D geometrie I can create an wonderfull mesh with prism layer in gmsh. But with 3D geometrie I do not have any succses to create an prism layer (with boundary layer field) on an surface of an volume body.
The api documentation tell me.
2.13.0 (July 11, 2016): new ONELAB 1.2 protocol with native support for lists;
new experimental 3D boundary recovery code and 3D refinement algorithm; better
adaptive visualization of quads and hexahedra; fixed several regressions
introduced in 2.12.
2.15.0 (December 4, 2016): fixed several regressions (multi-file partitioned
grid export, mesh subdivision, old compound mesher); improved 2D boundary layer
field & removed non-functional 3D boundary layer field; faster rendering of
large meshes.
It seems the support is dropped on december 4, 2016. So, can I enable the featrue manuelly?
Anyone do have information when it is planed to enable the prism layer generation again?
There are equal meshing tools with the support of prism layer generation?
Can I solve the problem in gmsh with an work around (e.g. subvolume generation near the surface)?
Thanks, Thomas
ThomasEnzinger is offline   Reply With Quote
Old   February 20, 2020, 05:18
Ferdinand Pfender
FerdiFuchs is on a distinguished road
hi thomas,
the feature was not functional.
Sadly, there are not much unstructured meshing tools with boundary layer generation.
nevertheless, you can download the versions between 2.13.0 to 2.14.x try using the non functional feature.
you could use salome/netgen. This works most of the times.
You could also try to use engrid, which is not up to date;but someone posted some minor fixed and instructions to compile it on ubuntu 18.04 on one of the several forks. dont know which one, but you can find it on github.
kind regards,
ferdifuchs
FerdiFuchs is offline   Reply With Quote
Old   February 20, 2020, 10:58
Mianzhi Wang
wangmianzhi is on a distinguished road
This also bothers me for a long time. An easy way to create BL prism/hex would make GMSH a much greater tool.
Thanks, Thomas
wangmianzhi is offline   Reply With Quote
Old   February 21, 2020, 05:43
Thomas Enzinger
Thanks for the answers.
@FerdiFuchs
I played first with Salome and after that with Gmsh a while. Gmsh is a simple tool with all (expect prism layer) feature where needed to generate nice meshes. "simple" and focused to the main task makes it an very create tool, but the missing ...
Ok, I think I should switch back to Salome for CFD meshes with prism layers. One change for Salome ...
[Other] mesh airfoil NACA0012 anand_30 OpenFOAM Meshing & Mesh Conversion 13 March 7, 2022 18:22
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 07:28
[blockMesh] non-orthogonal faces and incorrect orientation? nennbs OpenFOAM Meshing & Mesh Conversion 7 April 17, 2013 06:42
[Netgen] Import netgen mesh to OpenFOAM hsieh OpenFOAM Meshing & Mesh Conversion 32 September 13, 2011 06:50
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 05:05
