Particle and gas flow through baffle geometry |
February 14, 2020, 04:35 |
Fredrik
Hi
I'm trying to simulate a gas flow containing solid particles through a gas dispersion plate in a conditioning tower. The problem is that the grid is way courser than the 3mm thin baffleplate (220mm, since the entire model is 51000mm). So how can i represent the geometry and still allow particles to flow through it? Will a 2D sub-grid baffle allow for particle flow-through? With a 1000Pa pressure drop. I'm using CPFD Barracuda Virtual Reactor Regards Fredrik |
February 14, 2020, 16:13 |
Rep Power: 7 |
Depending on the exact physics in the problem you might be able to solve the gas and powder/particle phases separately with a DEM approach. I know of at least one solver that will let you import an air flow field that provides momentum to the DEM particles.
enginsoftusa.com |
Setting the height of the stream in the free channel | kevinmccartin | CFX | 12 | October 13, 2022 22:43 |
Domain Reference Pressure and mass flow inlet boundary | AdidaKK | CFX | 75 | August 20, 2018 06:37 |
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 06:21 |
Multiphase flow - incorrect velocity on inlet | Mike_Tom | CFX | 6 | September 29, 2016 02:27 |
error message | cuteapathy | CFX | 14 | March 20, 2012 07:45 |
