February 7, 2020, 06:43 |
Laminar Buoyancy Driven Cavity
Hello together,
I am working at the moment on the problem of a Laminar Buoyancy-Driven Cavity. There is a SU2-tutorial for example on this topic (https://su2code.github.io/tutorials/Inc_Laminar_Cavity/), but there are also a lot of papers online concerning this problem. All have in common, that they use the ideal gas law in order to model the density and investigate the problem for rayleigh numbers of 1e3 to 1e6. This leads to very low densities for air (~ 1e-3 kg/m³) and I'm wondering why these cases are investigated, which are quite far from the standard air density. I would be very grateful if someone helped me on this topic. Kind regards |
February 7, 2020, 08:09 |
#2 | |
Troy Snyder
Rep Power: 19 |
I believe the typical range of Rayleigh numbers you listed are typical of buoyancy driven flows in liquids, e.g. water. |
February 7, 2020, 09:59 |
Filippo Maria Denaro
Rep Power: 73 |
Using non-dimensional form of the equation, no one will set air or any specific material as fluid .
density modeling law, heat transfer, ideal gas, rayleigh number, su2 |
Lid driven Cavity | suman91 | SU2 | 3 | May 24, 2022 06:23 |
Setting up Lid driven Cavity Benchmark with 1M cells for multiple cores | puneet336 | OpenFOAM Running, Solving & CFD | 11 | April 7, 2019 01:58 |
Lid driven cavity for pimple: solution oscillates | piu58 | OpenFOAM Running, Solving & CFD | 2 | February 12, 2017 11:13 |
Boundary Conditions at Corners, lid driven cavity | t.teschner | Main CFD Forum | 8 | August 17, 2016 09:20 |
is there any parallel code for the famous Lid Driven Cavity flow? | gholamghar | Main CFD Forum | 0 | August 1, 2010 02:55 |
