Simulating orifice plate with Finite Differences
Old   January 30, 2020, 21:34
Default Simulating orifice plate with Finite Differences
Matheus
Matheus.Costa is on a distinguished road
Hi there,
I'm working on my thesis right now and I need to make a numeric simulation of a flow through an orifice plate using the Finite Differences method, I'm still a beginner on CFD and I started reading some books such as: Computational Fluid Dynamics the basics with applications by John D. Anderson. The simplifications for Navier-Stokes that I'm using are: Steady flow, incompressible flow, Newtonian fluid and the heat transfer can be neglected. Also, since I'm working with a flow through a tube, it would be more advisable to use cylindrical coordinates.
I would appreciate if any of you guys could point me some books that work using finite differences, I'm having trouble on setting the initial conditions and
boundaries while coding, the software that I'm using is Matlab by the way, and the results that I need are velocity gradient and the pressure gradient associated to it.
I started coding and was able to set the geometry for orifice plate, but wasn't able to understand well the boundary and initial conditions, also the discretizion using cylindrical coordinates weren't so simple for me, I found it easier for me, I'm using central differences on space, since it's steady flow I'm not using any derivative on time.
Thanks in advance for anyone who could share some tips and guidance with me.
Matheus.Costa is offline   Reply With Quote
finite difference method, matlab, orifice plate, presure, velocity gradients
massflow inlet on cooling plate definition inside the ambient air box farianka FLUENT 0 March 21, 2017 07:27
finite plate --> Infinite plate??? student CFX 1 March 26, 2008 13:20
Multigrid for finite differences Enda Bigarelli Main CFD Forum 4 November 6, 2001 13:04
Finite differences Zdravko Stojanovic Main CFD Forum 8 March 24, 2001 23:31
U.F.D. :Finite Differences on Unstructure grids STROHM Main CFD Forum 4 August 6, 1998 16:25
