Reconstruction and flux approximation in FVM
Like Tree14Likes
Old   January 31, 2020, 04:44
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
Originally Posted by vesp View Post
Why would multi D Riemann solvers be important? all the FV codes I have seen in use at big conpanies just use 1D RP solvers normal to the faces...
Yes but that is a low order accurate reconstruction. Consider that some propagation directions are privileged, that is the directions orthogonal to the faces of the volumes. This may lead to large numerical errors, especially if the mesh is not a classical Cartesian one.
There exist several papers in literature showing the improvement in using multidimensional Rieman solver. For example I remember some tests showing the carbuncle phenomenon disappearing.
FMDenaro is offline   Reply With Quote
Old   January 31, 2020, 04:46
sbaffini's Avatar
Paolo Lampitella
sbaffini will become famous soon enoughsbaffini will become famous soon enough
Send a message via Skype™ to sbaffini
Originally Posted by FMDenaro View Post
What book do you think is better for that
Let me say that, in my opinion, for different reasons, they are both awful for beginners. Still, of course, they both have merits.
sbaffini is offline   Reply With Quote
Old   January 31, 2020, 05:35
Originally Posted by Eifoehn4 View Post
Yes that's maybe true, but i think it is also hard to skip this topic when someone starts to learn the finite volume theory and you have to explain him afterwards e.g. things asked by TurbJet.
In my opinion it is really helpful to introduced common finite volume
approximations along with the Riemann problem theory.
The books of Leveque and Toro are good references, but i would also suggest to use second literature, where the focus is more on numerical methods, especially for the incompressible Navier Stokes equations.
Regards
Skipping this topic no, but there is a theoretical issue for adopting the Riemann problem as general basis for a FVM, in a general viscous flow there is no longer the existence of Riemann invariants as well as of a discontinuity. So approaching the problem this way is only a first order accurate factorization between convection and diffusion of momentum.
Old   January 31, 2020, 05:36
Paolo, as you know is impossibile to have a single textbook as a standard for teaching CFD. Better to have a couple of reference for each level of CFD courses.
sbaffini likes this.
finite volume method, reconstruction scheme
Computing the flux at an arbitrary 2D surface andy_pr OpenFOAM Programming & Development 0 August 7, 2018 15:23
How to apply heat flux at the interface when using VOF method? princekar FLUENT 0 November 15, 2015 08:47
Finite volume methods, reconstruction, etc. Nereus Main CFD Forum 9 January 31, 2012 17:12
[Commercial meshers] ST_Malloc: out of memory.malloc_storage: unable to malloc Velocity SA, cfdproject OpenFOAM Meshing & Mesh Conversion 0 April 14, 2009 16:45
