Symmetry/slip wall boundary condition in potential flow around a cylinder
Like Tree6Likes
Old   January 23, 2020, 16:02
ilia Nikiforov
ilia.nikiforov is on a distinguished road
Originally Posted by FMDenaro View Post
That means
Div v =0
dv/dt + div (vv) + Grad phi = 0
That is a first order hyperbolic system of equation in the velocity field, the "pressure" phi being only a lagrangian multiplier (just apply the curl to the momentum). Again, only one condition is required on the boundary. Since the fluid is ideal, you cannot set the physical non-slip condition and only the normal velocity is prescribed to fulfill the continuity equation.
To have two BCs you need a second order equation, that is the momentum equation with the diffusive term in the RHS.
Thank you very much for your help, looks like I need to review systems of PDEs in general, thank you for pointing me in the right direction.
ilia.nikiforov is offline   Reply With Quote
Natural convection in a closed domain STILL NEEDING help! Yr0gErG FLUENT 4 December 2, 2019 01:04
Velocity vector in impeller passage ngoc_tran_bao CFX 24 May 3, 2016 22:16
Basic Nozzle-Expander Design karmavatar CFX 20 March 20, 2016 09:44
Problem in setting Boundary Condition Madhatter92 CFX 12 January 12, 2016 05:39
Low torque values on Screw Turbine Shaun Waters CFX 34 July 23, 2015 09:16
