January 22, 2020, 15:06 |
MRF for transient , is it possible?
Rep Power: 12 |
Hi
I am working in a model consist of rotation and multi-phase flow. I am using openFOAM and my solver is reactingTwoPhaseEulerFoam which is Two-Fluid solver. I have inlet and outlet and there is an inner cylinder that is rotating. I used MRF for rotation. I run my model and after a long time, I did not see a steady-state condition. Because I used MRF, supposedly result only after reaching steady state is reasonable. since in this solver Dynamic mesh is not added, I stuck to MRF. Can you help me with it? any idea how I can tackle this problem? I saw discussions in the CFD forum that talk about transient MRF. I compared two similar cases (mixerVessel2D) by running in reactingTwoEulerFoam+MRF and VOF+Dynamic mesh. Apparently the results are the same with some error. Can we use MRF for the transient regime? I appreciate it if you help me with it Regards Roshanak |
June 10, 2022, 07:16 |
Rep Power: 8 |
multiphase fluid movement is highly transient bc of phase interaction in every timestep.
mrf is a steady-state approximation. you will mix two different time approaches. |
July 6, 2022, 13:52 |
#3 | |
Vivek MJ
Rep Power: 6 |
if you have a weak system and want to work with dynamic mesh then coarsen the mesh |
simpleFoam: Influence of MRF region dimensions on simulation results | Krao | OpenFOAM Running, Solving & CFD | 4 | March 29, 2022 22:33 |
MRF and topoSet problem- Rotating volume doesn't rotate | andreas0209@hotmail.com | OpenFOAM | 1 | April 4, 2021 14:35 |
Possibly serious MRF implementation issue | Ali Blues | OpenFOAM Bugs | 1 | December 16, 2015 07:04 |
MRF setup | andreas0209@hotmail.com | OpenFOAM Pre-Processing | 1 | August 6, 2015 10:36 |
Should an empty MRF zone really induce this much cross-flow? | sylvester | OpenFOAM | 5 | November 18, 2010 04:48 |
