Calculating change in Relative Humidity
Old   January 15, 2020, 07:55
Default Calculating change in Relative Humidity
Muhammad Usama
Usama1034 is on a distinguished road
I have inlet air and water temperature and initial Relative Humidity of the air.
I have a CFD model that can calculate the change in Temperature of water due to evaporation in a Control Volume.
However, change in temperature or evaporation is accompanied by an increase in Relative Humidity. How can I calculate the increase in Relative Humidity for my Control Volume? I can calculate increase in vapor mass (that's how I'm calculating evaporation energy)
Usama1034 is offline   Reply With Quote
Old   January 16, 2020, 11:14
Lucky
What's your psychometric model? How do you define humidity?
It might also be helpful to describe any details of your model beyond "I have a CFD model"
[solids4Foam] How to calculate drag coeff when using solids4Foam amuzeshi OpenFOAM CC Toolkits for Fluid-Structure Interaction 15 November 7, 2019 13:50
Relative Humidity modelling Ahmed Hassan ANSYS 1 July 15, 2019 11:02
relative humidity problems PaRa Fluent Multiphase 0 May 12, 2017 10:03
How do I detect the amount of water evaporated from relative humidity? gzsakuraz Fluent UDF and Scheme Programming 0 March 20, 2017 08:40
Relative humidity subhas.hunasikatti@gmail. Fluent UDF and Scheme Programming 0 January 8, 2014 04:26
