Sharat Chandrasekhar
Rep Power: 6 ![]() |
Is it possible to obtain meaningful velocity profiles for fully developed pipe flow with one-dimensional (radial coordinate only) finite difference simulations using the k-epsilon class of turbulence models ?
I know that this can and has been done using mixing length models, but wanted to check with the experts on this forum before embarking on a fool's errand. Thanks |
#2 | |
Filippo Maria Denaro
Rep Power: 73 ![]() ![]() ![]() |
andy
Rep Power: 18 ![]() |
Yes. It may not be particularly informative with respect to the velocity profile though because it will simply follow from a linear shear stress. If you know the wall stress from your boundary conditions then the details of the turbulence model becomes irrelevant to the velocity profile.
It can be done, and I actually suggest it as a useful toy model to learn dealing with turbulence models and/or wall functions.
The same holds, obviously, for other simple settings, like the simpler channel or the boundary layer. The latter however is more interesting because it is the basis for some wall function approaches. However, it depends from what you want to do. Along the same lines, if you extend the approach to the 2D section you can use it as inflow generator (but to be useful you would need it for unstructured 2D grids) |
Hello, I'm trying to solve for the complete velocity profile, not just the near wall region, in a concentric annulus.
#6 | |
#7 | |
Consider that for the k-epsilon family of models you are going to need a wall function, even if in 1D. So, what you will see is how this performs more than how the k-epsilon performs. As a matter of fact, most wf models actually mimic the mixing length model, so you might not see any specific difference.
Maybe try the k-omega family or the Spalart-Allmaras. |
fully developed flow, k-epsilon turbulence |
Fully developed flow and convergance | soumitra2102 | Main CFD Forum | 3 | September 11, 2019 09:50 |
Fully Developed Flow in Star-cd | SMM | STAR-CD | 0 | September 5, 2011 22:08 |
Fully Developed Flow | kpsudhakar | CFX | 4 | June 7, 2010 06:03 |
Simulating fully developed flow in a pipe | Tim Donohue | CFX | 1 | November 20, 2007 20:24 |
udf for 3D laminar fully developed flow | salman | FLUENT | 0 | November 9, 2006 21:45 |
