channel flow, too large reynolds stress <u'u'> near the wall
Old   January 7, 2020, 03:59
Default channel flow, too large reynolds stress <u'u'> near the wall
niewiemnic
spalartallmaras is on a distinguished road
Hallo,
Cuz I could not have answers in OpenFOAM forum, I post this question once more.
I simulate channel flow for Re_tau=395 for long time, but I have always really large <u'u'> near the wall. I simulate with pimpleFoam.
Inlet, Outlet, left and right are cyclic and walls are wall.
My setup is,
1. nu=2,53e-03 (so 1/nu=395)
2. bulk velocity is about 22-23 m/s (patchMeanVelocityForce on inlet), so wallShearStressMean and u_tau are also about 1. Density is supposed to be 1 kg/m^3.
3. turbulence model is WALE-Modell
4. because Re_bulk is low, I use createBoxTurb before the pimpleFoam.
(4-1. Or I start my simulation with nu=2,53e-05 and if the flow is turbulent enough, I change viscosity to nu=2.53e-03 again.)
5. Mesh is really coarse, 32*32*32, because I want to make the mesh fine later.
6. After the flow is turbulent enough, I switch on the fieldAverage1.
7. Time steps are with maxCo = 0.99 variable.
but I have always <u'u'> about 20-22 m^2/s^2 near the wall. But it should be about 7-8 m^2/s^2 from Reference.
What will be the problem?
spalartallmaras is offline   Reply With Quote
Old   January 7, 2020, 04:17
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
Originally Posted by spalartallmaras View Post
Hallo,
My setup is,
Because using such coarse grid you capture nothing close to the wall?
Plot the rms along y+
FMDenaro is offline   Reply With Quote
Old   January 7, 2020, 04:19
niewiemnic
thank you for your answer and sorry, in y-direction the number of grids is not 32. y+ are,
y+
0
0.441067194
1.040592885
1.855612648
2.963478261
4.469565217
6.516600791
9.299604743
13.0826087
18.22490119
25.21501976
34.7173913
47.63241107
65.19367589
89.06324111
121.5059289
165.6126482
194.3201581
223.0237154
251.7272727
280.4347826
309.1383399
337.8458498
366.5533597
395.256917
423.9525692
452.6482213
481.3833992
510.0790514
538.7747036
567.5098814
596.2055336
624.9011858
669.0118577
701.4624506
725.3359684
742.8853755
755.8102767
765.2964427
772.2924901
777.43083
781.2252964
783.9920949
786.0474308
787.5494071
788.6561265
789.486166
790.0790514
790.513834
Old   January 7, 2020, 04:29
vesp is on a distinguished road
check your streamwise resolution, having very unbalanced resolutions csn causesuch issues
vesp is offline   Reply With Quote
Old   January 7, 2020, 05:04
y+
0
0.441067194
1.040592885
1.855612648
2.963478261
4.469565217
6.516600791
9.299604743
13.0826087
18.22490119
25.21501976
34.7173913
47.63241107
65.19367589
89.06324111
121.5059289
165.6126482
194.3201581
223.0237154
251.7272727
280.4347826
309.1383399
337.8458498
366.5533597
395.256917
423.9525692
452.6482213
481.3833992
510.0790514
538.7747036
567.5098814
596.2055336
624.9011858
669.0118577
701.4624506
725.3359684
742.8853755
755.8102767
765.2964427
772.2924901
777.43083
781.2252964
783.9920949
786.0474308
787.5494071
788.6561265
789.486166
790.0790514
790.513834
You have 48 nodes in vertical direction and only 1 node is at y+<1, that is a coarse grid. You first need to improve the wall resolution (at least 3-4 nodes at y+<1) to check the rms at the walls.
Of course, I am talking about a wall resolved approach, not a wall modelled one.
Old   January 7, 2020, 10:48
niewiemnic
https://github.com/OpenFOAM/OpenFOAM...LES/channel395
I try simulation newly with this tutorial setup and my max. nondimensional reynolds stress is about yet 13-14... Cuz I use mesh of tutorial file, it should work well.
Max. dimensional reynolds stress is about 0.0018 m^2/s^2 and (u_tau)^2 is about 0.00013 m^2/s^2 (Density is 1 kg/m^3).
so the max. nondimensional stress is 13.85 [-]...?
Old   January 7, 2020, 11:13
Before continuing the discussion, post here the plot of u+(y+) that you obtained. Post also the three rms plot. I suggest to superimpose the DNS solutions you can get from well known data-base.
Are you fixing the pressure or mass driving force? Explain how are you forcing the flow in streamwise direction. Have you tried to get a solution without any model?
Generally, the peak in the rms close to the wall is obtained in LES at a greater value than DNS, see here https://www.researchgate.net/publica...mulation_codes
Old   January 8, 2020, 01:05
niewiemnic
Sorry that I dont know how can I upload images here.
https://drive.google.com/open?id=1v-...jZ_mh-UebgWSXF
Here you can download graphs for u+ and uu+
If vv+ and ww+ help to give me advices, I will upload also the graphs soon.
I let velocity constant in domain with
momentumSource
    type            meanVelocityForce;
    selectionMode   all;
    fields          (U);
    Ubar            (0.1335 0 0);
Here you can read about the meanVelocityForce (https://caefn.com/openfoam/fvoptions-meanvelocityforce),
The meanVelocityForce fvOptions calculates a momentum source so that the volume averaged velocity (1) in the whole computational domain (all) or a part of domain specified using cellSet or cellZone reaches the desired mean velocity Ubar.
p.s. I try to simulate with nu=2e-05. Calculated (estimated) Re_tau is unfortunately about 350, not 395.
Old   January 8, 2020, 03:58
momentumSource
    selectionMode   all;
    fields          (U);
    Ubar            (0.1335 0 0);
You can clearly observe that your computed flow rate is quite greater than the DNS one. This effect is common in a LES solution with excessive turbulent viscosity and coarse grid resolution. I suggest You:
1) compute a solution without any SGS model
2) try to use the dynamic model
3) refine the grid doubling the number of nodes
Old   January 9, 2020, 08:27
niewiemnic
I am really thankful for your advices.
https://drive.google.com/open?id=1hU...IDrcl_sAICyrt0
There are two new graphs for u+ and uu+ with dynamic smagorinsky sgs model.
First, I made mesh finer in every direction, expecially in the direction of height doubled,
y+
0.000
0.375
0.787
1.240
1.738
2.284
2.884
3.544
4.268
5.064
5.938
6.899
7.954
9.113
10.386
Now there are 100 nodes in the direction of height.
And I used dynamic smagorinsky sgs model.
Finally the max. value of <u'u'> is reasonable, but still there are error in coordinates. Can you help me a little bit more?
p.s. sorry that I didnt try DNS myself cuz I never used DNS till now. The DNS-Values in the graphs are from a reference.
Old   January 9, 2020, 08:34
There are two graphs for u+ and uu+.
y+
0.000
0.375
0.787
1.240
1.738
2.284
2.884
3.544
4.268
5.064
5.938
6.899
7.954
9.113
10.386
100 nodes in vertical direction are now good but, as you can see from the plot of u+ (I suggest to use a semi-log plot as it is a standard in literature), your solution is wrong, very different from the DNS but also from similar LES solutions obtained using OF. I suppose you have some problem in the setting of your case.
Just to be sure, how long do you wait before to start sampling the data for the statistical averaging of the velocity? Have you assessed to get only the fields after a statistically steady state is reached?
Wall shear stress in channel flow sreeyuth OpenFOAM Running, Solving & CFD 2 September 5, 2014 11:02
UDF for wall slipping HFLUENT Fluent UDF and Scheme Programming 0 April 27, 2011 13:03
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 21:30
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 06:13
X-Y plot of Yplus in Fluent 5.3 Luo FLUENT 24 April 11, 2000 07:07
