Conjugate Heat Transfer doesn't describe Solids in Fluent |
January 1, 2020, 13:55 |
Bobby Charlton
Hello guys,
I am trying to study the cooling of air that is flowing inside a steel pipe that sits in ambient air. I have modeled the 3 different domains (air-environment domain, steel pipe domain, air flowing domain) and have created a part of all three domains. I have a great structured mesh. I have set the temperature of the air-environment at 273 K through the Fixed Values option in the Domains tab. The air is still and not moving so I have not defined any inlets/outlets. I have set the steel pipe domain as a solid. I have defined a velocity inlet (2 m/s and 320 K) and pressure outlet (0 pascals, 300 K backflow temperature) for the domain of the air flowing inside the pipe I get a wall and shadow wall for the outer surface of the pipe, which is set as Coupled. I have the same for the inner surface of the pipe. I am running the simulation and I am getting a result but when I get a temperature contour of a cross-section of the whole pipe, I get a specific temperature at the normal direction of the heat flow, instead of a classic conduction profile inside the pipe. There is no gradient of the temperature inside the steel pipe. I only get a temperature drop in the direction of the flow (axial direction) but not in the radial direction. Note that I get an expected gradient for the ambient air and the air inside the pipe. Does anybody know what's up with this? I am trying to get the temperature profile of the steel pipe without doing an FSI with Fluent and Static Thermal. I even tested a regular wall with two air domains on each side, one hot and one cold, and I still don't get a conduction profile, just a specific value of the temperature (a specific color in the contour). I have created and meshed the solid geometry of the wall. Thanks! |
[ANSYS Meshing] Fluent Conjugate heat transfer: Temperature at a small fluid region exceed limit | RPjack | ANSYS Meshing & Geometry | 1 | June 20, 2019 08:11 |
conjugate heat transfer in OpenFOAM | skuznet | OpenFOAM Running, Solving & CFD | 99 | March 16, 2017 06:07 |
Running UDF with Supercomputer | roi247 | FLUENT | 4 | October 15, 2015 14:41 |
Question about heat transfer coefficient setting for CFX | Anna Tian | CFX | 1 | June 16, 2013 07:28 |
Conjugate heat transfer and radiation modeling questions | shankara.2 | FLUENT | 0 | April 21, 2009 16:55 |
