Airfoil: sign of moment from the lifting force? |
December 27, 2019, 09:14 |
Burut
Rep Power: 6 |
Hi, if the airfoil is fixed on the 1/4 line and the lifting force is created, then the moment from the lifting force is positive or negative (i.e. the profile will rotate clockwise or counterclockwise), give an example of some kind of profile. suppose, according to the rules of mechanics, it should reduce the angle of attack (i.e., rotate counterclockwise), what do you think?. Thanks.
Problem with airfoil shape optimization | robyTKD | SU2 Shape Design | 7 | March 7, 2022 17:18 |
Incorrect lift force in simpleFoam airfoil simulation | olov | OpenFOAM Running, Solving & CFD | 2 | May 18, 2019 07:51 |
udf writting force and moment in a file at each time step | lostmmind | FLUENT | 0 | March 25, 2015 01:13 |
Center of pressure (confirmation/question) | scipy | FLUENT | 2 | March 5, 2012 07:54 |
Airfoil Drag Force | wowakai | Main CFD Forum | 3 | October 13, 1998 20:27 |
