Default Stream function - vorticity boundary conditions for Couette flow |
December 24, 2019, 11:43 |
pelkeini
I want to solve Couette flow without pressure gradient using stream function - vorticity formulation. I need two boundary conditions for each plate Krogerfeedback.com. I know that velocity and stream function values are zero on lower plate. Also, for the upper plate, the derivative of stream function equals to the velocity (U). I need one more boundary condition. Which boundary condition should I use for the upper moving plate? Last edited by melkwin; December 26, 2019 at 21:15. Reason: Spelling |
December 24, 2019, 12:31 |
#2 | |
Filippo Maria Denaro
Rep Power: 73 |
Wind turbine simulation | Saturn | CFX | 60 | July 17, 2024 06:45 |
[Other] mesh airfoil NACA0012 | anand_30 | OpenFOAM Meshing & Mesh Conversion | 13 | March 7, 2022 18:22 |
Issues on the simulation of high-speed compressible flow within turbomachinery | dowlee | OpenFOAM Running, Solving & CFD | 11 | August 6, 2021 07:40 |
Radiation in semi-transparent media with surface-to-surface model? | mpeppels | CFX | 11 | August 22, 2019 08:30 |
ParaView for OF-1.6-ext | Chrisi1984 | OpenFOAM Installation | 0 | December 31, 2010 07:42 |
