December 20, 2019, 00:18 |
Does pressure influence flow over density?
I have two 1cuft containers under vacuum.
Both containers are in atmospheres that have the same air density. Container #1 is in atmosphere with 0.075lb/cuft with 70F temperature and 29.92inHg. Container #2 is in atmosphere also with 0.075lb/cuft, but with a temperature of 80F and 30.5inHg. If there is a valve on each container and they are opened for 0.1ms, will both containers have that same amount of atmosphere, or will container #2 have more since pressure is higher? |
December 20, 2019, 03:07 |
Lucky
Rep Power: 66 |
It depends how big is this valve, but nominally yes.
December 20, 2019, 10:04 |
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 06:21 |
How to manage the pressure term in fixed mass flow rate based channel flow simulation | sjwon1991 | Main CFD Forum | 5 | July 10, 2017 08:21 |
Multiphase flow - incorrect velocity on inlet | Mike_Tom | CFX | 6 | September 29, 2016 02:27 |
reference pressure and compressible flow | bingo10 | CFX | 0 | September 11, 2013 08:32 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 10:11 |
