FLUENT Scaling - Force Coefficients
Old   December 8, 2019, 11:40
Default FLUENT Scaling - Force Coefficients
sbro is on a distinguished road
Hi all,
I'm running a 2D thin airfoil simulation in FLUENT which returns force coefficients for lift and drag at 6 degrees AoA with a chord length=1m of CL=0.60 and a Cd=0.018.
I've re-run this case (same AoA) with a scaled model (1/4c) and the same Reynolds number (model scaled by a factor of 1/4, therefore free-stream/inlet velocity has been doubled and the kinematic viscosity halved to maintain consistent Re) expecting to return equivalent values for the force coefficients but this hasn't been the case; solution returned CL~0.15 and a Cd~0.0045 which is a quarter of the original solution.
As the Re is the same and the mesh has been scaled with the airfoil surface (giving same Y+) I don't understand the reasoning for this or if i've simply made a mistake configuring the sim?
Any advisement would be greatly appreciated! Thanks.
sbro is offline   Reply With Quote
Old   December 8, 2019, 14:59
flotus1's Avatar
Alex
flotus1 has a spectacular aura aboutflotus1 has a spectacular aura about
Did you adjust the reference length to match your scaled model? From the coefficients you obtained, it seems like you forgot to do that.
flotus1 is offline   Reply With Quote
Old   December 9, 2019, 09:01
Thanks for the reply.
You're correct that I forgot to adjust the reference length but, having re-run the simulation now, I'm still obtaining the same result(?)
Old   December 9, 2019, 09:23
flotus1's Avatar
Alex
I should have been less specific. What I actually meant was "reference values" instead of reference length.
Lift and drag coefficients are calculated using the reference area.
Anyway, that's just post-processing. Changing reference values does not change the solution.
Old   December 9, 2019, 09:59
So, by scaling the geometry by a factor of 1/4 (in X & Y), am I correct in thinking the reference area should be amended by (1/4)^2?
For this case where I am keeping Re consistent, am I correct in thinking I should expect the same force coefficients (lift / drag)?
Thanks again for your help!
drag coefficient, lift coefficient, reynolds number, scaling
Pressure force UDF with Fluent rsarma Fluent UDF and Scheme Programming 3 May 24, 2021 12:35
Problem in using parallel process in fluent 14 Tleja FLUENT 3 September 13, 2013 11:54
problem in using parallel process in fluent 14 aydinkabir88 FLUENT 1 July 10, 2013 03:00
Force Contour Plots in Fluent 14.0 lew FLUENT 0 May 31, 2013 10:29
how does Fluent calculate the pressure and viscous force vector? Ralf Schmidt FLUENT 2 May 17, 2010 16:49
