subscale analogy for RANS
Old   November 26, 2019, 13:57
Default subscale analogy for RANS
Andy
Starcatcher is on a distinguished road
Hi folks,
the models inside of cells are called subscale models. That means that the length scale of an les cell is called subscale. What is the analogy to that for the much bigger RANS cells?
It's not "fine scale" beacuse that stands for the very smallest turbulent structures in the real flow.
Thanks
Andrew
Starcatcher is offline   Reply With Quote
Old   November 26, 2019, 14:07
Lucky
You can think of it in terms of filtering or a low-pass filter. But a subtle difference in LES and RANS is what exactly is being modeled.
LES is spatially filtered and you solve for the low spatial frequency components and end up needing to model the influence of high spatial frequency components (the subgrid model).
RANS/URANS can be interpreted as a temporal filtering. You solve for the low temporal frequency: the time-average in the case of steady RANS, and the slowly-varying components in the case of URANS. The influence of the high temporal frequency components, is your turbulence model where we most commonly use a Boussinesq eddy viscosity approach.
That is, subscale in the LES sense refers to sub-spatial-scales and in the RANS sense temporal scales. In LES, the filtering is usually linked to the the grid and hence we call these the the subgrid scales. In RANS, the temporal filtering doesn't really have anything to do with the grid. That's why we don't give it any fancy name.
Old   November 26, 2019, 14:30
Andy
cool thanks. What is with URANS? The time filtering there is qualitatively not different from the one in e.g. VLES. Can I then also use the term "subscale"?
Old   November 26, 2019, 14:32
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
Originally Posted by Starcatcher View Post
Hi folks,
Thanks
Andrew
There is no analogy between the concept of "subgrid scale model" used in LES and the turbulence model used in RANS. In LES the spatial filtering mimics a formal separation in the energy spectrum into a resolved and unresolved part. Only this latter is the object of the SGS model that acts on the smallest resolved scales. In RANS there is not such a separation, the entire spectrum is under statistical averaging and all the components are affected by the action of the turbulence model.
FMDenaro is offline   Reply With Quote
Old   November 26, 2019, 14:55
Lucky
I wouldn't recommend it, unless you want to upset your peers. There's better names already in use (e.g. turbulence model).
I posed an explanation for the analogy purely for educational & philosophical purposes.
fine scale, les, rans, subscale
TAB (Taylor Analogy Breakup) Model Zi-Wei Chiou Main CFD Forum 15 December 19, 2023 10:27
Mesh Generating Using Spring Analogy andromeda91 SU2 9 October 6, 2016 01:40
Sloshing pendulum analogy ybav223 Main CFD Forum 1 August 14, 2013 03:56
Can RANS turbulence model be used to check the validity of Reynolds Analogy? keryfluid Main CFD Forum 0 April 22, 2013 23:48
on spring analogy santoshaesi Main CFD Forum 0 May 21, 2010 03:57
